Tensioner/Idler pulley alternatives #1032955 08/11/11 02:55 PM
87Montero Offline OP
I thought I saw lots of communication in the past on the tensioner pulleys since the ones on eBay are $99 and they are 90 or so though mitsubishi parts (and no availability through local parts stores)
Anyways.. I'm sure we've beat this like a dead horse but I thought I'd throw this at the wall.
This is a mitsubishi tensioner idler pulley that everyone seems to think are made of gold:
This is the tensioner pulley for my 2003 Hyundai XG350.. The only difference I can find is that the center is recessed more than the mitsubishi one due to the pulley itself being taller for a wider belt.
FYI - the Hyundai one cost $11 from Rockauto! I'll have to compare it to the pulley that's actually on my mitsubishi.
Had anyone tried this yet?
Re: Tensioner/Idler pulley alternatives [Re: 87Montero] #1032956 08/11/11 03:00 PM
RECON45 Offline
Put it on and see. You might have to make a spacer for the deeper offset, but it should work fine if has the proper clearence. good find. Let us know how it goes.
Re: Tensioner/Idler pulley alternatives [Re: RECON45] #1032957 08/11/11 03:03 PM
The offset is the same as factory actually so It might not even need any spacing. It seems it's "deeper" because the pulley itself is taller by maybe 3/16" at most.
If my tensioner pulley wasn't the hardest one to get to I'd take it apart for the hell of it and put this on, but I bought it for my Hyundai anyway. I will keep the old Hyundai one and see how it fits when I get around to getting my radiator serviced in the mitsu.
Re: Tensioner/Idler pulley alternatives [Re: 87Montero] #1032958 08/11/11 03:47 PM
There's also a goodyear #4975 (IIRC) that fits width, but needs 5 flat washers behing the pulley to space it out right. Runs like a charm. Costs under $20, IIRC...
Re: Tensioner/Idler pulley alternatives [Re: fasteddy] #1032959 08/12/11 08:12 AM
4ePajero Offline
IIRC, the idler pulley off the VW 4-cyl OHC engine is a perfect fit, and available at very low price.
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: Tensioner/Idler pulley alternatives [Re: 4ePajero] #1032960 08/12/11 02:38 PM
justice Offline
Looks great, let us know if it works so I can order some.
Re: Tensioner/Idler pulley alternatives [Re: 4ePajero] #1032961 08/12/11 06:42 PM
KrzyDav Offline
which VW 4 cly OHC?????
dave h.
Re: Tensioner/Idler pulley alternatives [Re: justice] #1032962 09/14/12 01:12 AM
justice Offline
Need one of these..Did we ever confirm that it worked?
Re: Tensioner/Idler pulley alternatives [Re: justice] #1032963 09/14/12 02:28 PM
I know the goodyear pulley works - no clue on the veebub.
Re: Tensioner/Idler pulley alternatives [Re: justice] #1032964 09/15/12 12:20 AM
haztoys Offline
There now is a listing for them at a lot of places now ...I run Mits V6 Caravan pulleys cheaper ez to find ...You needs a few washers and it works fine ...The bearings replaceable on the ones I have too..
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6428 MB (Peak: 0.7664 MB) Data Comp: Off Server Time: 2026-11-02 12:30:25 UTC
