YJ Tailgate Question #1033008 08/12/11 10:46 PM
Jim_Paget Offline OP
I have an '89 YJ tub on an 88 frame. I bought was was advertised as a YJ tailgate. It has the latch in the tailgate, but came without the striker mechanism. Since the latch in in the tailgate, the striker would have to be in the bed of the tub. Yet when I look at striker mechanisms on EBAY, it is obvious that the striker is part of the door.
Are there two versions?
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: YJ Tailgate Question [Re: Jim_Paget] #1033009 08/12/11 11:40 PM
BobRowe Offline
Is your tailgate hinged on the side or on the bottom?
Re: YJ Tailgate Question [Re: Jim_Paget] #1033010 08/13/11 12:01 AM
4x4Wire Offline
87-95 YJ tailgates are all the same. Note, the TJ tailgates are the same physical size with same hardware but hinges are in different spots.
The striker should be about a 3/4" dia. round piece bolted into the side of the tub. The latch is in the tailgate.
If you need the latch assembly, let me know as I have a couple of tailgates kicking around.
I don't have a spare striker...
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: YJ Tailgate Question [Re: 4x4Wire] #1033011 08/13/11 07:54 AM
BobRowe Offline
I'm aware of that. I asked about the hinges to see if perhaps he had bought a CJ tailgate by mistake.
Re: YJ Tailgate Question [Re: BobRowe] #1033012 08/13/11 02:04 PM
4x4Wire Offline
Figured you did. That was for Jim's benefit...
John Stewart
Editor - 4x4Voice
Re: YJ Tailgate Question [Re: Jim_Paget] #1033013 08/14/11 01:07 PM
MartySoCal Offline
The striker bolts to a bracket that bolts to the left rear opening of the tub. The striker is the same one that is used on the doors, if I remember correctly. The bracket that mounts it is different.
Re: YJ Tailgate Question [Re: MartySoCal] #1033014 08/16/11 03:14 AM
Thank you all for responding. My tailgate hinges on the side.
Evidently there are a lot of people on ebay selling strikers that are not for a YJ but they say that they are. Some of them even have pictures of the striker mounted on the door.
Jim Paget
www.rrr4x4.com
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6186 MB (Peak: 0.6921 MB) Data Comp: Off Server Time: 2026-07-13 21:18:40 UTC
