CAUTION - 95 Front Brake Caliper Bracket Bolts
#1033247
08/16/11 04:16 PM
Suggestion for 95 (and possibly earlier) Montero Owners - Replace the front caliper bracket bolts with some from an older model. Or at least add some lock washers to the original 95 bolts. The 95 bolts do not have lock washers. The later models have bolts with lock washers.
Full Story - About 1 year ago I picked up a pair of front brake calipers at a junk yard. These came from a 96 or 97 model. I was looking for a good pair of calipers that I would use to keep from having to pay a core charge and make two trips to NAPA. I replaced my 95 calipers with NAPA calipers about 9 months ago. When I pulled my 95 calipers I noticed the 95 bolts did not have lock washers, while the junk yard calipers had bolts with lock washers. I decided to use the 95 bolts.
Last evening the bottom bolt on the passenger side fell out. This let the caliper rotate into the wheel. I had a great deal of noise when this happened. <img src="/forums/images/graemlins/scared.gif" alt="" /> Thankfully, I was only about 1 mile from home and it was mostly up hill. I removed the other 3 remaining 95 bolts and replaced them all with the later style bolts and lock washers.
I thought about putting the later style bolts on my 95 when I replaced the calipers. But, at the time I figured I would keep the 95 bolts. It seems that Mitsubishi decided to change the bolts after 95. It seems like they added the lock washers for a good reason.
If you have a 95 or possibly earlier Montero, I would suggest that when you replace the front calipers it would be a good time to add some lock washers. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: CAUTION - 95 Front Brake Caliper Bracket Bolts
[Re: MarkG]
#1033248
08/16/11 04:36 PM
I had the same problem happen to me. I replaced all the bolts and washers with grade 10.9 stuff and put loctite on the bolts. I think the stock ones on my 90 had loctite on bolts stock. No problems so far.
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
[Re: heathdogg]
#1033249
08/16/11 06:29 PM
This is common problem across all models. I have a feeling the bolts deform with time from heat.
[Re: MarkG]
#1033250
08/16/11 07:01 PM
Did you ever get that LSD rear put in? John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
[Re: willwinchforfood]
#1033251
08/23/11 03:43 AM
I'm sorry to say "not yet". <img src="/forums/images/graemlins/frown.gif" alt="" />
I was getting some parts together (brake rotors, fixed radiator, LSD rear end and other parts) when a wren decided it wanted to build a nest under the hood. <img src="/forums/images/graemlins/baby.gif" alt="" /> I'm now waiting for the youngsters to fly away. As fast as they are growing, they will be gone in less than a week. <img src="/forums/images/graemlins/wink.gif" alt="" />
