Fuel filter replacement question. #1033540 08/25/11 03:14 AM
Coondog Offline OP
Reading the Haynes repair manual for my 89 Yota I read that I need to de-pressureize the fuel line beofre taking off the fuel filter. I have no idea what that means can someone explain what I need to do and why?
Thanks in advance!
Re: Fuel filter replacement question. [Re: Coondog] #1033541 08/25/11 03:48 AM
kewlynx Offline
The line pressure is a LOT higher than it is for a carbed Toy engine. You'll get fuel all over the place if you don't.
WEAR EYE PROTECTION.
Crack gas tank cap.
Easier to loosen fuel lines if you leave the filter bolted on. You can either loosen the line slightly and let it bleed off, or loosen the line at the fuel manifold. I do the former.
You can also find this info in the 93 FSM in the sticky at the top of this section. OR HERE
Take some time to become familiar with our website; lots of good stuff here.
Store or dispose of your dirty rags/fuel safely so as not to burn anything down later. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" />
**ubi apis- ibi salus**
Re: Fuel filter replacement question. [Re: kewlynx] #1033542 08/25/11 05:40 PM
OOP'S Offline
All the above, plus do it when the engine is cooled off!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Fuel filter replacement question. [Re: OOP'S] #1033543 08/26/11 05:32 PM
RatLabGuy Offline
And be prepared for the fact that the thing is NOT easy to get to.
Question Reality.
Re: Fuel filter replacement question. [Re: RatLabGuy] #1033544 09/04/11 10:59 PM
G
Greg_Canada Offline
Get a clean jug and drop the line into the jug... i've had a litre of gas come out before the pressure goes down (really don't know how it does that)...
89 4Runner
Re: Fuel filter replacement question. [Re: Coondog] #1033545 09/14/11 02:58 AM
Coondog Offline OP
Well I got the filter changed. I was kind of a pain in the arse. A different PIA than my old 87 Chevrolet, but none the less a PIA!
I didn't do anything but disco the lines from the filter. It bled about a measure cup of gas out. The tank was more or less empty... that I didn't find out untill I took the flatbed off and removed the pump LOL!!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6120 MB (Peak: 0.6816 MB) Data Comp: Off Server Time: 2026-06-07 07:24:20 UTC
