Page 3 of 4 1 2 3 4
Re: Engine does not start! please help! [Re: mxmikie] #1033824 09/10/11 04:12 PM
justice Offline
Agree with MX. Talked to Carlos on the phone last night. Given the current situation, told him to check the timing marks. He checked the belt at the drivers side top cover and said its OK, but I think he somehow jumped time. It might be impossible to line up marks now that the engine has some sort of obstruction...but it will turn counter clockwise..Heads will probably need to come off now regardless...but checking the marks will give him an idea of what happened.
Re: Engine does not start! please help! [Re: justice] #1033825 09/10/11 05:20 PM
Oyaji_Jon Offline
Yuck...Good luck, Carlos...
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Engine does not start! please help! [Re: Oyaji_Jon] #1033826 09/11/11 04:14 AM
Stopped by Carlos'. Bruno was there. There is some news. Will let Carlos tell it. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Engine does not start! please help! [Re: off-roader] #1033827 09/11/11 06:08 AM
cap510 Offline OP
So it looks like I got some bent valves and some broken exhaust valves. <img src="/forums/images/graemlins/frown.gif" alt="" /> SOAB!
Hard decisions to be made!
Feeling mix feelings! <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: Engine does not start! please help! [Re: cap510] #1033828 09/11/11 08:11 AM
Oyaji_Jon Offline
I think you've got too much in that rig not to fix it, but that's just me. Replace the heads/t-belt and call it a day? What would you replace it with if you didn't fix it?
Sorry to hear of the bad outcome. That sucks!
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Engine does not start! please help! [Re: Oyaji_Jon] #1033829 09/11/11 09:27 AM
cap510 Offline OP
Well, I got 3 monteros in my driveway... Need to get one trail worthy!
I found a potential doner for my SR so we'll see what happens!
Re: Engine does not start! please help! [Re: cap510] #1033830 09/11/11 03:40 PM
SeerAtlas Offline
Cap, I'm not clear on what happened to your motor. Was the conclusion that the 'bump" (must have been a hell of a bump:), caused the timing belt to jump cogs and thereby cause interference with the valves and pistons which trashed your valves? or did you suck water into the motor and that did it?
either way, it sux, but I'm in agreement with the rec to either get some new heads or rebuild, or did you mean by 'donor' you found another motor.
Seer
89LS,90LS,91LS,91LS,95SR,89JeepGrandWagoneer,90JGW,91JGW,92JGW,93RangeRoverLWB,93RRLWB,94RRLWB,94RRLWB,95RRSWB; 90'Dodgezilla' 1-Ton Cummins4x4.
Re: Engine does not start! please help! [Re: SeerAtlas] #1033831 09/12/11 01:36 AM
Hydrolock would have done things like popping the tops out of pistons or heads, bent/broken rods from the sudden stop, and other sudden stop problems, like a twisted crank.
Broken/bent valves is usually FOD or piston contact, unicylinder valve damage is usually FOD, multicylinder is piston contact, most often from a broken/jumped timing belt.
I confess that I'm not sold on the new belt tensioner system. The old spring loaded tensioner pulley seemed to work fine as long as the bearing in the pulley held up.
I would see if the heads can be repaired with new guides and valves and a touch of combustion chamber cleanup on the nicks if any, perhaps new valve seats, and you get the new valve stem seals and updated guides in the deal. This should not be terribly expensive, add a head set, timing belt and new idler pulleys and tensioner set, new front main seal, water pump, and you are set to go.
Re: Engine does not start! please help! [Re: SeerAtlas] #1033832 09/12/11 03:05 AM
cap510 Offline OP
It did not suck water. I am also surprise that what I went thru cause this problem, I had gone thru worse mud holes before and have jump my truck feets in the air and landed pretty and never had an issue.
I found a rebuilt engine local that might cost me less than rebuilding the heads. We'll see what happens, ill keep u guys posted.
Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Riding on 37" MTRs
Re: Engine does not start! please help! [Re: cap510] #1033833 09/12/11 04:55 AM
Beware rebuilt engines!!!
There has been a lot of bad luck on here with rebuilt long blocks. If your bottom end is sound, and it really should be, go with just the heads. The bottom end on these things is very stout oem, and lasts a long, long time with proper oil changes.
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6440 MB (Peak: 0.7689 MB) Data Comp: Off Server Time: 2026-07-14 21:49:18 UTC
