Page 2 of 3 1 2 3
Re: 95SR Plenum Butterfly Valve question [Re: mike5] #1034088 09/14/11 01:27 AM
sasnydley Offline
With my truck I sprayed some ether or something like it around the Intake I had leaks.esp at the rear side Butterfly bushing. Plus mine would run OK until up in torque curve then spit/sputter cough from air leaks. I replaced mine with new intake. just gives peace of mind. 1st one had around 126k on truck when replaced.
Re: 95SR Plenum Butterfly Valve question [Re: sasnydley] #1034089 09/14/11 01:34 AM
There is a "fix" and a fix.
The "fix" is to disable the actuator, wire the lever in a fixed position, and seal the shaft bushing with some like of sealant goo, rtv or similar.
The fix is to replace the plenum.
Re: 95SR Plenum Butterfly Valve question [Re: fasteddy] #1034090 09/14/11 03:52 AM
mxmikie Offline
i removed the butterflys and the shaft then plugged the ends on the manifold with steel plugs .... i have a manifold that has been plugged if anybody needs one
Re: 95SR Plenum Butterfly Valve question [Re: mxmikie] #1034091 09/14/11 04:31 PM
That's what was done to mine, Mx. Maybe we can call that the "fix*".
Re: 95SR Plenum Butterfly Valve question [Re: mxmikie] #1034092 09/14/11 05:33 PM
Yeah, Carlos (cap510) did the same thing with his.
Re: 95SR Plenum Butterfly Valve question [Re: off-roader] #1034093 09/15/11 03:34 AM
Who wants to be a guinea pig? Do a set of 5 0-60mph runs with the arm set the way it is now, a set of 5 with the arm fastened all the way the other way, and a set of 5 with the arm halfway. average each set of 5. This will tell us which "fix"ed setting is the right one for power.
Re: 95SR Plenum Butterfly Valve question [Re: mike5] #1034094 09/15/11 11:57 AM
SeerAtlas Offline OP
Mike, if you're hearing that clicking, according to all I've been able to find out,, including talking to the chief mitsu mechanic in this area, it's time to get that plenum out of there. It's when you hear the clicking that the screws holding the butterfly are in real danger of backing out dropping into your intake at which point you are going to trash some cylinders. The rebuild or replacement of the motor is big money. Best to take care of this sooner than later.
Seer
89LS,90LS,91LS,91LS,95SR,89JeepGrandWagoneer,90JGW,91JGW,92JGW,93RangeRoverLWB,93RRLWB,94RRLWB,94RRLWB,95RRSWB; 90'Dodgezilla' 1-Ton Cummins4x4.
Re: 95SR Plenum Butterfly Valve question [Re: SeerAtlas] #1034095 09/15/11 08:18 PM
mike5 Offline
Seer,
I agree with the assesment. My hope is to get it done in the next month. I am just not in a rush to spend $1000!
Looking online it looks like the cheapest I can find the part is roughly $375 and usually plus shipping or tax. Is that about right? Also, anyone make rebuilt versions?
Mike
Re: 95SR Plenum Butterfly Valve question [Re: mike5] #1034096 09/16/11 02:46 AM
I think I will just go with what eddy said and seal up the ends. Im not so interested in top-end as I am in torque and bottom end.
Re: 95SR Plenum Butterfly Valve question [Re: Mudraider] #1034097 09/16/11 07:47 PM
TheViper Offline
I wish someone would post a "how to" on this...with pics of course
1995 Montero SR
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6404 MB (Peak: 0.7642 MB) Data Comp: Off Server Time: 2026-06-10 01:41:43 UTC
