Opinions on a new clutch #1034505 09/16/11 10:30 PM
0778drz110 Offline OP
Well I burnt up the clutch in my raider, so I've been driving the car instead. But I'm tired of driving this thing so I'm going to replace the clutch next summer when I get home from school.
So do I put a heavier duty clutch in it and hope the km145 doesn't explode, or put in an oem clutch and keep it the weakest link?
I'm worried if I put a centerforce(or similar) that the transmission might fail not long after. Before the clutch began to slip I didn't have any problems with it.
Re: Opinions on a new clutch [Re: 0778drz110] #1034506 09/17/11 03:06 AM
I used a no-name clutch set from the local pop shop, mom no longer worked there. I've put around 80 thousand miles on it and had no troubles. Everything from water trailers, 33" tires, camper trailers, and another Raider were towed.
Re: Opinions on a new clutch [Re: 0778drz110] #1034507 09/20/11 02:49 AM
Skibane Offline
In my (limited) experience, there's nothing particularly "weak" about the genuine OEM clutch. Mine is currently closing in on 200K of not-particularly-gentle driving.
The Redneck Special: 88 Ram 50 2WD XCab with 167K on the original 2.6L, 5-Sp, Weber 38DGS, Crane HI-6 with timing adjust, 4-for-$100 tires, Generac 4000EXL 4KW AC generator, Hampton Bay 12KBTU window air conditioner sticking through a hole hacked in the back of the cab...All it needs now is a gun rack...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5942 MB (Peak: 0.6477 MB) Data Comp: Off Server Time: 2026-06-17 13:24:21 UTC
