motor locked up? #1034775 09/21/11 04:03 AM
Brice Offline OP
Howdy you all!
My dad and I bought a 86 Montero 4cyl, 4x4 5 speed with a locked up engine.
it had a brand new head installed and was ran for 10 minutes..locked up and we cannot spin it at all.
before I go and pull and yank it apart, is there anything I should look specifically at?
Re: motor locked up? [Re: Brice] #1034776 09/21/11 04:35 AM
Timing chain may have locked up, piston in the bore, crank rod bolt sticking out...there are numerous possibilities.
Re: motor locked up? [Re: rxinhed] #1034777 09/21/11 01:32 PM
Brice Offline OP
We have tried to turn it both ways...it will not budge, at all.
I guess we pull the motor and take it apart to see. Hope its not a major major..
Re: motor locked up? [Re: Brice] #1034778 09/22/11 07:15 PM
pulling the valve cover will give you a look at the top of the timing chain, and the rockers. I had one lock up from a piece of a disintegrating jet valve jamming between cam and head.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6017 MB (Peak: 0.6571 MB) Data Comp: Off Server Time: 2026-07-16 03:42:39 UTC
