Montero/Raider standard transmission vs Ford Ranger #1034790 09/21/11 02:24 PM
RyanB Offline OP
Does anyone know if there is any huge differences between the KM145 put in the Montero and the KM145 put in the 4x4 Ford Rangers from 1988 to 94ish?
The Ranger transmissions are a lot more common around here and I was wondering if it would be a direct swap. I would assume the input shaft would be different, but I do not know.
Thank you,
Ryan
1984 Mitsubishi Montero, 2.6l - 5 speed
Re: Montero/Raider standard transmission vs Ford Ranger [Re: RyanB] #1034791 09/21/11 10:40 PM
0778drz110 Offline
I think the FM145 has a different bell housing. They put it behind Ford 2.9 V6s.
Re: Montero/Raider standard transmission vs Ford Ranger [Re: 0778drz110] #1034792 09/22/11 12:20 AM
plh Offline
If I remember correctly the FM145 has a removable bell housing, and it will not mate to the Mitsu transfer case. Spencer has one behind is MM diesel, but uses a divorced Atlas transfer case.
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Montero/Raider standard transmission vs Ford Ranger [Re: plh] #1034793 09/22/11 02:22 AM
RyanB Offline OP
I knew you guys would know. Thank you! I am pretty sure I want to rebuild it or have it rebuilt now that I have thought about it. I figure get it done right and then I won't have to worry about it again.
Thanks again,
Ryan
Re: Montero/Raider standard transmission vs Ford Ranger [Re: plh] #1034794 09/22/11 02:27 AM
0778drz110 Offline
He has one from a diesel ranger with the 4d55. It has the correct bolt pattern for a 2.6, but good luck finding one.
They didn't use the FM145 up until 1994. The Fm145 was on older early to mid-80s rangers. The M5OD was used in the late 80s and into the 90s IIRC.
Re: Montero/Raider standard transmission vs Ford Ranger [Re: 0778drz110] #1034795 09/22/11 03:27 AM
plh Offline
I have one of those rare as hens teeth bellhousings. If anybody wants it, I would for sure sell it. Doubtful I'll get around to using it.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Montero/Raider standard transmission vs Ford Ranger [Re: plh] #1034796 09/23/11 05:42 AM
spencevans Offline
As stated above, I mated the FM145 behind my 2.3 diesel so that I could marry an Atlas T-case to my FM145 transmission. Due to the design the KM145 it is not possible to marry it to an Atlas transfercase. The biggest between the two transmission is the slave cylinder. The FM145 uses an internal slave cylinder and the KM145 uses an external slave setup.This may not seem like a big deal, but it is a big difference. Because of this, the Ford master cylinder's bore is much larger. I could go on and on about the differences, but the reality is, to convert from transmission to the other, modifications need to be made to the tunnel, firewall, master cylinder, speedo cable, driveshafts, frame and crossmembers, flywheel, clutch, slave cylinder and starter. It all adds up and before you know it, it can get really expensive.
Spence
Spence
1985 Mitsubishi PU 2.3 Turbo Diesel, 13" lift, Watercooled turbo, 4D56 Head, Atlas II,Fox Coilovers, Elockers,
1983 Mitsubishi PU 2.5 Turbo Diesel 4x4, fully restored
2003 G500, sliders, beadlocks, roofrack, ladder etc.
Re: Montero/Raider standard transmission vs Ford Ranger [Re: spencevans] #1034797 09/23/11 03:09 PM
dadrab Offline
Man, that ain't a modification; it's a re-engineering. <img src="/forums/images/graemlins/scared.gif" alt="" />
with awesome audio.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6278 MB (Peak: 0.7278 MB) Data Comp: Off Server Time: 2026-06-07 09:13:14 UTC
