Car wont start and Code 86 #1034865 09/22/11 09:58 AM
BAZINGA Offline OP
Just jumped into my car to head home, and it wouldn't start. Got a tow home. The battery has a good charge. Checked the error codes via the engine light and returned only 1 code: 86
Couldn't find what this was.
No idea where to start. One minute it was ok, now its not.
AAARRRGGGHHH!!! <img src="/forums/images/graemlins/frown.gif" alt="" />
Its a 99 auto
forgot to mention that by dead/wont start, I mean it wont even crank over. All the lights on the dash come on.
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: Car wont start and Code 86 [Re: BAZINGA] #1034866 09/23/11 05:40 AM
DRX350 Offline
Code 86? Not P0086 or something like that?
87 for OBDI is: 87 Malfunction Indicator Lamp short Circuit.
-OR-
P1486 EGR Solenoid Valve Vent Open or Short.
-Or-
P1586 A/T-M/T Codification
There is NO such code as "86"... Keep in mind you car is an OBDII controlled car.
Here's a list of codes:
trouble codes
"Does this part need to be in there?"
1996 Dodge 1500 single cab / short bed, 5.9 4x4; 2" lift (springs not blocks), C.A.I and more mods to come.
Re: Car wont start and Code 86 [Re: DRX350] #1034867 09/23/11 05:57 AM
BAZINGA Offline OP
It is not a P code as I don't have a reader. I checked the codes via the CEL. After rechecking a dozen times it is definately 86.
I'm about to check the timing belt.
Re: Car wont start and Code 86 [Re: BAZINGA] #1034868 09/23/11 07:08 AM
BAZINGA Offline OP
Well, I undid a few bolts on the top timing belt cover and had a peek inside. Everything looks good. There is tension on the belt.
I tested the power to the starter solenoid and there is voltage.
So, shouldn't the starter motor kick over?
Re: Car wont start and Code 86 [Re: BAZINGA] #1034869 09/23/11 09:12 AM
BAZINGA Offline OP
Well, it looks like DTC 86 is "Starter Solenoid/Starter Motor". I remembered an old trick I used on an XC Falcon I had.
HIT THE DAMN THING WITH A HAMMER!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
Problem solvered.
But I will still need to take it off, clean/inspect/repair.
Re: Car wont start and Code 86 [Re: BAZINGA] #1034870 09/23/11 10:52 AM
TheGoat Offline
been hitting the starter on my miata for a year... 1 out of every 5 starts it won't crank.. out comes the 3 foot 1/2 inch extension.. smack twice, start car..
although, i'm surprised we have a CEL for that??
So, i bought an 01 Kia Sportage. before i even drove it, i nick-named it The Goat.. it has been just like a goat.. stubbern at every corner...
Re: Car wont start and Code 86 [Re: TheGoat] #1034871 09/23/11 11:11 AM
BAZINGA Offline OP
Well, it's not official, there is no record of it anywhere. I know that by using a reader you get more codes. I have seen the same DTC posted in various forums but no resolution. It would be nice to have it confirmed.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6217 MB (Peak: 0.7122 MB) Data Comp: Off Server Time: 2026-05-29 16:11:57 UTC
