Page 5 of 6 1 2 3 4 5 6
Re: 5.38 ring and pinions [Re: Peabody] #1035320 02/03/13 06:00 AM
E
E30Newbie Offline
I got my gears put in this weekend. On 31's it took the truck to just a touch lower than it was stock. Very nice. On my 33's it is just a touch lower than on my 31's. I must say, I'm happy with the money put out and the install was very easy. If anyone has these sitting around and has questions about the install or parts needed please let me know. I would be glad to help.
A few teaser pics ( though you can't see the gears )
Excellent tuck
[img]http://i145.photobucket.com/albums/r221/rkossol/a77eac6e3ec1e74fa36e6f399476bfce_zps463b57ce.jpg[/img]
Re: 5.38 ring and pinions [Re: E30Newbie] #1035321 02/03/13 07:12 AM
Dez Offline
That bumper is bad ass. What tires are you running?
Re: 5.38 ring and pinions [Re: Dez] #1035322 02/03/13 03:52 PM
Everet Offline
Post some more pictures of your bumpers and rear shock relocation. Are your bumpers modified from something off the shelf or did you do custom made units? Several guys here are really wanting a source of bumpers. Did you install lockers too? How did you clear the front fender behind your 33's? How much lift do you have total?
Think your rig is really great!
Re: 5.38 ring and pinions [Re: Everet] #1035323 02/03/13 09:47 PM
Peabody Offline
Looks good! Nice work on the bumpers, rack and winch!!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
I'm running 31's and my speedo was reading about 5 mph faster than I was going with the new R&P set. I was able to calibrate it with the TruSpeed box Everet had brought to our attention a while ago. I also found that my gas mileage dropped about 2-3 mpg. It improved some after running the rear gears for 500 miles and changing out the gear oil... but that may also have been due to the oil level being slightly overfilled from the initial install. I like the 5.38 gears - makes it a little quicker off the line. But I'm running around 3250 rpm at 70 mph. Sounds like my little engine is screaming!!! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Nice work! Looking forward to more photos and build details!!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 5.38 ring and pinions [Re: E30Newbie] #1035324 02/04/13 07:00 AM
TeamCatFlap Offline
Nice. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Don't really need them with my current tires, but if I ever want to go big I should probably obtain a set to have on hand.
2001 Kia Sportage
Warn manual hubs, 2" spacer up front, TJ 105 springs Rav4 shocks, 235/75/15 BFG A/T KOs, Skidplate back to under the T-case, trans cooler, XRC8 winch on custom bumper, Synth winch line, fuel can mount, Rigid D2 Dually overhead lights.
Re: 5.38 ring and pinions [Re: TeamCatFlap] #1035325 02/05/13 10:30 PM
E
E30Newbie Offline
I am running 33x12.50 r15 Pro Comp X Terrains that I cut and siped
Thanks Everet. You have been a big help throughout this build. I have recommended you to a few of my other Oregon buddies.
I built the bumpers from scratch and the winch holder too (allows no blockage of the headlights). Bumpers are plate steel, channel, and angle iron. I have photo's at home but here is a link to my your tube video. I has a few pics of the build in it around 2:48. I will get some pics of the rear build this evening
http://www.youtube.com/watch?v=VrHKTdMsmWs
The rear shocks were easy. Simply weld in a piece of angle between the frame rails and weld on mounting tabs (aka bolts). Move the shock tops to more of a Toyota type position. Make some mounts and move the bottom of the shocks to the inner axle housing. Makes it ride great and Improves flex by 200%. See pics below
Thank you. I am off by 2 mph now but its okay with me.
Man, you have no idea what you are missing. Lots of power is lost from a factory to an over sized tire. does not seem like much but after you run big tires for a few months than try a factory size, its very noticeable. I HIGHLY RECCOMEND you make the swap. Takes less then 8 hours start to finish and that includes setting up the pattern. It is so worth it I can not describe it. Being able to crawl is priceless and much easier on everything.
Thanks for the kind words everyone. If you need any more information please let me know. I would be happy to lend a typing hand <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 5.38 ring and pinions [Re: Peabody] #1035326 02/11/13 09:32 PM
DennisThompson Offline
You have done an awesome job on your Sporty, sometimes I miss working on mine but still love the Jeep. Even though you can buy anything for a Jeep I am still building my own bumpers and will be building my own long arm kit.
keep up the good work, Dennis
Re: 5.38 ring and pinions [Re: DennisThompson] #1035327 04/08/13 04:37 PM
masagero Offline
Hi guys interested in ring and pinion 5.38 for Kia Sportage from where do I order?
Re: 5.38 ring and pinions [Re: masagero] #1035328 04/14/13 06:42 AM
Peabody Offline
Re: 5.38 ring and pinions [Re: Peabody] #1035329 05/30/13 10:08 PM
sidthekid Offline
that email is not working for some reason anyone have luck with contacting theme ?
01 sportage upyourkia coilover kit warn manual hubs 31" tires 16" wheels 104aa springs toyota rav4 shocks https://www.facebook.com/UpYourKia
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6540 MB (Peak: 0.7885 MB) Data Comp: Off Server Time: 2026-10-22 04:06:48 UTC
