Timming belt and Head Tutorial (soon) #1035354 09/29/11 08:18 PM
Blehaa Offline OP
First I want to thank everyone who has or had a part in building these forums up. I understand how much time goes into documenting repairs, upgrades and just posting General Questions. This has helped tremendously; and is now my turn to give back. I recently purchased a 97 Montero LS (3.5 SOHC 6G74) and not knowing when anything was changed out, I want/need to do a major overhaul/tune up. I am going to be replacing the timing belt because of the motor type and check out an oil leak on my Left Head, So I figured I might as well replace the following.
TIMING BELT ITEMS
ò Timing Belt kit
o Water pump
o Actuator
o Camshaft Belt Idler
o Camshaft belt Tensioner
o Water pump seal and gasket
ò Cam Shaft Seal
ò Spark Plugs (x6 NGK laser platinum)
ò NGK Wire Set
HEAD ITEMS
ò Air intake fitting gasket
ò Intake plenum gasket
ò Throttle body gasket
ò Valve cover gasket (x2)
ò Plug guide seals (x6)
ò Coolant outlet pipe o-ring (x2)
ò EGR pipe gasket
ò Exhaust valve guide seals (x12)
ò Inlet valve guide seals (x12)
ò Head Gasket (x2)
I have made this list from all the forums IÆve seen and have sent emails out to people asking for their advice, (Thank you Off Roader, Fast Cat, Mad Scientist and Fast Eddy) I will be ordering all the above items within a week, just want to make sure I havenÆt missed anything, (IÆve been going over this for a while now) And need new EXPERIANCED eyes to take a look. I will be making a full tutorial out of this for members to come, because a lot of the older posts no longer have pictures. Thank you for any help you can give.
Re: Timming belt and Head Tutorial (soon) [Re: Blehaa] #1035355 09/29/11 10:41 PM
Grasscat Offline
Thing you need to know.
The rocker cover gaskets have now turn to a hard plastic and a pain in the butt to to get out. That's why you have a leak there. Also the spark plug guide seal will be the same way, but come out easier.
I also find it helpful to reinstall the bolts after removing a part where possible, like brackets for instance. I also keep them separated for major items, it's easy to get them mix up ( same size different lengths ).
Don't for get your coolant and a 22mm socket for the crank bolt.
Michael j
TreadLightly! Trainer
Re: Timming belt and Head Tutorial (soon) [Re: Grasscat] #1035356 09/30/11 12:07 AM
Blehaa Offline OP
Great, Thanks for the added tips Grass Cat. I Added all the items to my shopping cart and Im very surprised a the price. Heres My order for this Fix
DAYCO Timming Belt Componet Kit -PN WP287K1A - 162.79
FEP-PRO Cylinder Head Gasket Set -PN HS26193PT - 123.79
VICTOR Timing Cover Gasket Set -PN JV5134 - 18.98
FEL-PRO Cylinder Head Bolt -PN ES72859 - 28.89
Gates Thermostat 170deg -PN 33877 - 10.38
total w/Shipping $432.79
Ill be Adding to the list
Coolant - $30.00
Tension Adjuster Pin Wrench Timing Tool - $20.00
Anything else anyone can think of? Thanks again Grass Cat <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Timming belt and Head Tutorial (soon) [Re: Blehaa] #1035357 09/30/11 12:33 AM
mxmikie Offline
and dont forget to change the thermostat and heater hoses while you are there
Re: Timming belt and Head Tutorial (soon) [Re: mxmikie] #1035358 09/30/11 01:58 AM
Blehaa Offline OP
I had the thermostat listed, But didn't think about my hoses... Great Point. Thanks Ill add it to the List <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Timming belt and Head Tutorial (soon) [Re: Blehaa] #1035359 10/01/11 02:02 AM
remember, the truck must be parked pointed due east when you start the work (to curry the favor of it's ancestors), and you must sprinkle a touch of your ancestors ashes at each corner of the truck (to introduce them to the truck's ancestors), then circle the truck three times chanting "Mighty Murphy, spare this sinner, Mighty Murphy, spare this sinner!" in a reverent voice. Self flagellation is not generally required in most cases, unless the crank bolt won't come off. May the gods not need a laugh.
Re: Timming belt and Head Tutorial (soon) [Re: fasteddy] #1035360 10/01/11 02:28 AM
TheViper Offline
It would be absolutely amazing if someone could do a video or step by step with pics for the DOHC 3.5. Still this is gonna be a great resource to have
1995 Montero SR
Re: Timming belt and Head Tutorial (soon) [Re: fasteddy] #1035361 10/03/11 05:02 PM
Blehaa Offline OP
I cant park it east, can I borrow your ashes? On a different note, it did make me Laugh, Thanks...
Re: Timming belt and Head Tutorial (soon) [Re: TheViper] #1035362 10/03/11 05:05 PM
Blehaa Offline OP
I like the video tutorial idea, but I don't have a DOHC, but I think Ill do a video instead, I don't have to worry about YouTube loosing my video,.. Great Idea
Re: Timming belt and Head Tutorial (soon) [Re: Blehaa] #1035363 10/03/11 09:40 PM
TheViper Offline
Thanks...actually ive been looking to buy another monty, one with the SOHC, so i cant wait to see this...meanwhile ive been watching youtube videos on people replacing timing belts, hard to believe their are none for the Montero. Anyways a video would be great, just try to have adequate lighting.
Any idea when u might do this big project?
1995 Montero SR
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6391 MB (Peak: 0.7648 MB) Data Comp: Off Server Time: 2026-07-14 10:50:41 UTC
