Re: Timming belt and Head Tutorial (soon) [Re: TheViper] #1035364 10/04/11 06:27 AM
Blehaa Offline OP
I ordered all the parts this morning, and depending on weather (its raining now) because I was going to do this out side, but may need to do this in the garage... I'm hoping very soon, I also will add the Sun Roof Tutorial also,
Re: Timming belt and Head Tutorial (soon) [Re: Blehaa] #1035365 10/04/11 06:53 AM
The thanks arent needed. Your posting up a how to is thanks enough.
Consider replacing the front seal especially if it's been there for a while... Eventually they will leak. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Timming belt and Head Tutorial (soon) [Re: off-roader] #1035366 10/04/11 07:00 AM
Blehaa Offline OP
Im sorry, but what "Front Seal" are you referring to? (oil seal) I ordered the master seal and Gasket set, for the Top End, along with Timing belt, and Water pump Seals and Gaskets.
Re: Timming belt and Head Tutorial (soon) [Re: Blehaa] #1035367 10/04/11 02:57 PM
Front main seal/crankshaft seal. Mine leaks.
Re: Timming belt and Head Tutorial (soon) [Re: Blehaa] #1035368 10/04/11 05:58 PM
What JohnnyB said. It's the front main seal which is probably not part of that kit you have. I'd buy the OE mitsu part if you can. Will likely be better quality. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Timming belt and Head Tutorial (soon) [Re: off-roader] #1035369 10/05/11 02:44 AM
I don't see the heater hoses that come off the back of the heads and go to the firewall. You'll have the intake off it sounds, so may as well change those.
Haven't done the 3.5 SOHC, but on the 3.0 24V, there is a water pipe that connects the heads at the back. Dependind on what all you are doing, you may end up taking it off, in which case you'll need the gasket.
If you are pulling the intake, that means the fuel rail. Get new gaskets and o-rings for the injectors. And while your at that, may as well change the few that are in the fuel rail itself.
Fel-Pro has a kit that is the VC gaskets and the plug tube grommets.
If you haven't changed a TB on a Mitsu 6G7X, the trick when putting the new belt on is to get the belt wrapped from the PS head gear, over to the DS (around the ater pump on the way), around the idler, then when you go to get it on the cranks gear, first turn the crank counterclockwise (as you look at it from the front of the truck) ~1/2 tooth. You will be able to easily get the belt into the gear, then turn the crank clockwise to take up the DS slack.
Get the special tool for the tensioner pulley for the pre-tensioning. If you do it right, the grenade pin on the hydro tensioner will come out with no resistance.
Damn that was fun to type. Makes me want to go out to the garage... <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Timming belt and Head Tutorial (soon) [Re: MontyMcV] #1035370 10/05/11 02:33 PM
dadrab Offline
Heed these words especially. You don't want to have one of these hoses rupture after you've put everything back together.
(I know what I'm saying here...bag on head. Lazy will bite your ass everytime.)
with awesome audio.
Re: Timming belt and Head Tutorial (soon) [Re: dadrab] #1035371 10/07/11 05:07 PM
Blehaa Offline OP
Just an update, all the parts will (or Should) be here the beginning of next week.
Re: Timming belt and Head Tutorial (soon) [Re: Blehaa] #1035372 10/14/11 09:22 PM
Blehaa Offline OP
According to Fed-ex online delivery, all the parts have now been delivered and should be waiting for me when I get home. I will start the process Saturday afternoon...
Re: Timming belt and Head Tutorial (soon) [Re: Blehaa] #1035373 10/25/11 01:12 AM
Clem1 Offline
How did it go? I just bought a '99 Montero with 96,000 miles and it is still on the original timing belt. I'll be tackling this job in the next few weeks. It would be great to see your video.
Clem
1999 Mitsubishi Montero (Winter Package)
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6382 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-07-14 10:50:28 UTC
