Remove gen1 engine 3.0 with trans and transfer case attached? #1036018 10/13/11 06:05 PM
crazyhal Offline OP
remove gen1 engine 3.0 with trans and transfer case attached or just engine? the bell housing bolts look to be a son of gun to get to....any tips or tricks?
1990 SWB 3.0
Re: Remove gen1 engine 3.0 with trans and transfer case attached? [Re: crazyhal] #1036019 10/13/11 06:11 PM
IIRC, others mentioned you need to use a combination of U-joints and extensions to get to those bolts but then again that may have been for the 2.6L.
I'm sure others have taken out their 3.0L though so they should chime in. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Remove gen1 engine 3.0 with trans and transfer case attached? [Re: crazyhal] #1036020 10/13/11 06:20 PM
Great time to install a body lift. Even if you don't do that, it'd probably be worth your time to just undo the body mount bolts and jack the body off the frame a bit. Might add an hour to the project if you're taking your time.
Re: Remove gen1 engine 3.0 with trans and transfer case attached? [Re: crazyhal] #1036021 10/13/11 06:49 PM
stevec Offline
Once I had my engine fully detached from everything (except for the trans) and hanging on the engine hoist, I was able to wiggle it around enough to easily get to all of the bell-housing bolts.
You might need to detach the trans from the frame too, to make it more wiggle-able.
steve
90 LWB Montero, 3.0 V6 EFI SOHC, MT, original owner
Re: Remove gen1 engine 3.0 with trans and transfer case attached? [Re: stevec] #1036022 10/13/11 09:33 PM
dadrab Offline
Wobble extensions and open-end/closed/end wrenches.
Re: Remove gen1 engine 3.0 with trans and transfer case attached? [Re: dadrab] #1036023 10/14/11 04:10 AM
Remove the tcase from the tranny. Let the tranny output drop. Go over the top of the tcase with lotsa extensions with at least one wobble at the socket end. You can't see jack, so a helper with skinny hands to noodle the socket onto the bolt is nice. I have a pretty good average of hitting it unaided, but I think that's luck.
Re: Remove gen1 engine 3.0 with trans and transfer case attached? [Re: fasteddy] #1036024 10/14/11 07:07 AM
For the two 4-doors I've parted, I removed the engine first, then dropped the trans & t-case while still attached to the cross member. Once the trans/t-case was down, I jacked up the left side of the frame and pulled the assemblies out. Took about 1 hour on the first car, 3 on the second due to more things needing removal (auto vs. stick).
Re: Remove gen1 engine 3.0 with trans and transfer case attached? [Re: rxinhed] #1036025 10/14/11 07:28 AM
crazyhal Offline OP
im just changing engine and clutch......i would rather tranny/transfer case stay in truck. maybe lifting body is the way to go?
1990 SWB 3.0
Re: Remove gen1 engine 3.0 with trans and transfer case attached? [Re: crazyhal] #1036026 10/15/11 12:11 AM
FrankR Offline
Once the lower intake is off, the engine is easily unbolted from the top of the bellhousing. Once the exhaust crossover is unbolted and the starter removed, the side and bottom bellhousing bolts are easy.
Frank
Re: Remove gen1 engine 3.0 with trans and transfer case attached? [Re: FrankR] #1036027 10/15/11 02:57 AM
Va_Stumpy Offline
Ratcheting wrenches ,multiple extensions & swivels make it "easier".....I removed the radiator & all the goodies from the front of the engine for extra clearance...
Good luck! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6395 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-07-17 02:19:07 UTC
