TSB-91-00-0003 (adding friction modifier to the manual transmission) #1036231 10/17/11 04:31 AM
8
89IsMine Offline OP
As the title states, there is a TSB for 89-91 Monteros and 4wd trucks describing adding friction modifier (ME580150) to the manual transmission.
Anyone doing this with theirs? If so, what brand of friction modifier did you use? Just a "generic" one for LSDs or did you go with the specific Mitsubishi product?
I'm curious as I bought some "Trans-X Posi-Trac" friction modifier today, but thought I would check the collective wisdom here before adding this to my M/T.
Thanks! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: 89IsMine] #1036232 10/19/11 05:30 PM
8
89IsMine Offline OP
Hmmm. 64 views and not a single response <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I guess I'll just have to try it and see what happens <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Eric W.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: 89IsMine] #1036233 10/19/11 05:47 PM
Grasscat Offline
Eric
Most of us have auto transmissions so this would not apply. The rest may have not seen the TSB. You're right, try it and see what happens. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Michael j
TreadLightly! Trainer
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: Grasscat] #1036234 10/19/11 06:41 PM
8
89IsMine Offline OP
Exellent point, Michael! Hadn't really thought that one through <img src="/forums/images/graemlins/smile.gif" alt="" />
Eric W.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: 89IsMine] #1036235 10/19/11 06:42 PM
Nothing from me. I have an auto, but interested because I have a 5-speed getting a motor this weekend. Did the plh tuff-pan, but really scared of the thing the way everyone bad-mouths the manual.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: Mudraider] #1036236 10/19/11 06:47 PM
8
89IsMine Offline OP
Ah, it's not that bad. You just learn to double-clutch your downshifts on the gears where the syncros are... questionable <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Eric W.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: 89IsMine] #1036237 10/19/11 07:15 PM
I am a bit late here, why would you want to add friction modifier to a manual transmission?
Most of us want our syncros to actually grip. The friction modifier reduces grip which can do nothing but bad things to a transmission.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: OldColt] #1036238 10/19/11 07:36 PM
8
89IsMine Offline OP
I guess it begs the question then of why Mitsubishi would issue a Tech. Service Bulletin specifying the addition of one <img src="/forums/images/graemlins/confused.gif" alt="" />
Eric W.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: 89IsMine] #1036239 10/20/11 12:44 AM
Chief Offline
Wow <img src="/forums/images/graemlins/zombie.gif" alt="" /> this is new ...never heard of using friction modifier in the trans before.
May work, I mean it may make for smoother shifting.
Should be no concern for slipping. Synchros in a trans and clutches in a lsd serve totally different purposes.
Give it a try, if it doesn't work, drain it out and replace with fresh gear oil. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'89 Raider V6, AT, SAS'ed, Dana 44 front & rear, 5:38 gears, NP 231 T-case.
'97 Montero SR, cold weather package, 4.90 R&P, BATTLEZ suspension w/ 2" lift, JAOS grill guard & under body protection, custom rock sliders.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: 89IsMine] #1036240 10/20/11 01:48 AM
KrzyDav Offline
I read that bulliten awhile back and we got quite a conversation going. I haven't been on here much lately either.
I think the modifier is to help out with the slow synchros from 1st to 2nd. I just use Redline MTL - 1 or equivalent Amsoil in the trans. The only real important thing is that you "never" use GL5 gear oil as the sulfur in it eats your synchronizers.
dave h.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6443 MB (Peak: 0.7683 MB) Data Comp: Off Server Time: 2026-05-29 22:25:48 UTC
