Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: Mudraider] #1036241 10/20/11 03:13 PM
dadrab Offline
...but really scared of the thing the way everyone bad-mouths the manual.
I've a a manual 2.6 for almost 24 years - the same one. Don't beat the hell out of it, but it's not that bad a tranny. It's just not as bullet-proof as the other incarnations.
I've had mine rebuilt once in 245,000+ miles.
with awesome audio.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: dadrab] #1036242 10/20/11 03:57 PM
8
89IsMine Offline OP
Here's a link that Kevin C. posted a couple of years ago to an article that explains why the friction modifier should be added
Interesting read... (executive summary: paper-lined syncros <img src="/forums/images/graemlins/zombie.gif" alt="" />)
Eric W.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: 89IsMine] #1036243 10/20/11 05:10 PM
To clarify further...
All 5 forward speeds are in constant mesh and synchronized. The 1-2 synchro rings are paper lined. The 5th-and-reverse synchro assembly is on the mainshaft. Reverse uses a conventional idler gear, and the reverse gears are helical cut for quiet operation. The lubricant specified for this trans is API GL-4 or GL-5. Because of the paper-lined synchro rings, a friction modifier should be added to the lube fill. One bottle of friction modifier, Mitsubishi part #ME581050, should ensure smooth shifts.
Re: TSB-91-00-0003 (adding friction modifier to the manual transmission) [Re: off-roader] #1036244 10/20/11 07:21 PM
8
89IsMine Offline OP
...and to clarify even further, TSB-93-22-001 states:
Purpose
The manual transmissions/transaxles in Mitsubishi Motors vehicles require the use of API GL4 classification gear oil. Using an incorrect API classification gear oil may affect the shift effort and may cause transmission/transaxle component damage.
Use only gear oils having the API classification GL4.
Mitsubishi Diamond Gear Lube - A991ZC2X01 -- SAE 75W - 85W GL4, meets this requirement.
CAUTION: Do not use gear oils having the API GL5 classification. GL5 oils have additives which many chemically react with sintered copper synchronizer rings leading to manual transmission/transaxle damage.
So, sounds like GL4 gear oil plus a friction modifier is what my version of the V5MT1 transmission wants <img src="/forums/images/graemlins/smile.gif" alt="" />
Eric W.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6128 MB (Peak: 0.6854 MB) Data Comp: Off Server Time: 2026-06-07 04:41:35 UTC
