89 Raider gearshift plate orientation?
#1036261
10/18/11 04:43 AM
I neglected to note the orientation of the shifter plate when I removed the gearshift lever. This is the plate that has the concave portion with a slot cut through the center of it that the shift lever extends through into the transmission. The slot extends beyond the concave portion on one side and I am wondering if that orients towards the front or the rear of the truck? If anyone can set me straight on this I'd appreciate it.
Thanks! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
Re: 89 Raider gearshift plate orientation?
[Re: 89IsMine]
#1036262
10/19/11 06:30 AM
Oh, never mind. Once I went to put it on the transfer case housing the orientation was obvious.
In retrospect, I think I should have waited to put the gearshift boot cover on until after I had the levers mounted to the transfer case... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Eric W.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5915 MB (Peak: 0.6397 MB) Data Comp: Off Server Time: 2026-05-30 01:19:22 UTCValid HTML 5 and Valid CSS
