Max Towing 1500lbs?? #1036310 10/18/11 07:31 PM
TainterRacing Offline OP
Got a new montero needs some work.. but looking at it says 1500lbs towing why due to not much power???? That seems low. My car car do 3200lbs towing??
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
Re: Max Towing 1500lbs?? [Re: TainterRacing] #1036311 10/18/11 07:54 PM
LandRaider Offline
It's more about safe stopping than it is towing.
FWIW, I flat towed another raider with my diesel raider. Pulled fine, but was a lil scary when it came time to stop. You certainly would NOT be doing any panic stops.
Re: Max Towing 1500lbs?? [Re: LandRaider] #1036312 10/18/11 08:21 PM
don Offline
I think that's the safe limit of those 4 attachment nuts on the back plate.
I welded a 3500 lb receiver to that back plate, and it works quite well, since it's all part of the frame.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: Max Towing 1500lbs?? [Re: LandRaider] #1036313 10/18/11 08:57 PM
0778drz110 Offline
x2 Its the brakes. Montero Sports are rated for 5000lbs with trailer brakes. Trailer brakes, W/D hitch, and a trans cooler you could tow 5000lbs all day. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Max Towing 1500lbs?? [Re: 0778drz110] #1036314 10/18/11 10:21 PM
I pulled 4k with the 95sr, no trailer brakes. Just had to plan the stops and leave interval. Don't tow in rush hour traffic.
I towed the same weight with a gen1v6, but it was too slow. The 3.5 was marginal. This is on N GA hilly stuff. If you live on the flats, the gen 1 would have been tedious, but not too slow. Tow in 3rd mostly, too, on a/t's.
The 2.6 is just too gutless for any hilly towing above 1500lbs or so, for my taste. Too ADDHDDDHDHD...
Re: Max Towing 1500lbs?? [Re: fasteddy] #1036315 10/19/11 02:04 AM
The two door's wheelbase makes things a bit more sketchy as well.
I had my SR set up for trailer brakes, and that makes life much easier when towing on the freeway, particularly.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6107 MB (Peak: 0.6809 MB) Data Comp: Off Server Time: 2026-07-11 05:26:35 UTC
