Wrong fuse/what effect?? #1036598 10/22/11 03:16 PM
dave1223 Offline OP
There's a 10 amp fuse in the slot where the 15 amp EFI fuse should be,what will this do/or cause?
Re: Wrong fuse/what effect?? [Re: dave1223] #1036599 10/22/11 05:23 PM
4Crawler Offline
At the most the smaller fuse would burn out sooner than the proper size one. But if it did not, that just says that the load on the circuit is not over the fuse rating.
One minor thing is that the smaller the fuse rating the higher the resistance of the fuse. However that is in the range of small fractions of an ohm, so not likely a big deal.
Re: Wrong fuse/what effect?? [Re: 4Crawler] #1036600 10/22/11 06:33 PM
dave1223 Offline OP
Thanks....
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.5918 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-07-15 15:06:09 UTC
