Page 2 of 5 1 2 3 4 5
Re: my 2WD build [Re: Cochip] #1036643 10/28/11 04:19 AM
CJM Offline OP
that is just the "mock up" engine .. I have already built the 7mGTE
should be ~ 400 RWHP
83 Trekker SR5
NEW Trekker forum
Re: my 2WD build [Re: CJM] #1036644 10/28/11 06:00 AM
Cochip Offline
Very nice. I love my '94 with a 7MGE, this truck will scream with a 7mGTE!!
BTW I've heard that the "third head gasket",(swear the manual I read called it that),tends to leak over time causing oil to pool in each of the spark plug locations. Did you do anything to address this? I ended up unscrewing the three plugs and placing a oil plug gasket there along with the factory gasket and then re-tightening them.
Re: my 2WD build [Re: Cochip] #1036645 10/29/11 01:28 AM
CJM Offline OP
Yep .. I used a Cometic Metal head gasket and ARP head studs , as well as the new tube gaskets .. I'm sure I used silicone on the tube seal tops as well , but honestly , I built the engine 5 years ago ..
prepping the inner rockers for the new body mounts .. I of course found rust <img src="/forums/images/graemlins/frown.gif" alt="" /> .. so now I have to fix that first .. I was really surprised , this cab was in awesome shape no rust at all , or so I thought .. just goes to show you , even if you think you have no rust .. you probabally do !!
undercoating wire wheeled off , and looking great
and cut out rust !!
83 Trekker SR5
NEW Trekker forum
Re: my 2WD build [Re: CJM] #1036646 10/30/11 01:54 AM
CJM Offline OP
1 side done .. and ready
83 Trekker SR5
NEW Trekker forum
Re: my 2WD build [Re: CJM] #1036647 11/01/11 01:49 AM
CJM Offline OP
also got the drivers side cleand and prepped this weekend
and <img src="/forums/images/graemlins/frown.gif" alt="" /> .. drivers side has rust as well
I think to be safe , i'm going to cut it all out .. front and back rocker area , and strengthin both sides before I build the body mounts
and just for some giggles ..
heres the pile of removed edging and ground steel ..
83 Trekker SR5
NEW Trekker forum
Re: my 2WD build [Re: CJM] #1036648 11/12/11 03:59 AM
CJM Offline OP
so over the last week , I have been building my repair panels and today I was able to get them burnt in , rears as well
now with the rockers repaired , I was able to get the cab height finalized @ 9" from the rockers to the Ground . + I also started on the cab mounts
Because there are only going to be 4 mounts instead of 6 , I wanted to make sure there were going to be strong .
cut out some 3/16" plate and surrounded it with some tube
Tacked into place I will add some more supports later , when I turn the frame over .
1 more front frame mount tomorrow , then I can get on the front cab mount
83 Trekker SR5
NEW Trekker forum
Re: my 2WD build [Re: CJM] #1036649 11/13/11 03:38 AM
CJM Offline OP
and cab side mount
Bent up some 1/2" solid stock with the 3/16" plate . as well as a "fish plate" for the cab side , 1/2" stock actually goes threw the fish plate for a stronger "plug" weld , and a toyota stock body mount bushing , I now have the front mounted
and now the front of the cab is mounted
still have some supports and final welding to do when I can turn over the frame , but for now it's good to go
also .. the cab now has it final "stance"
acetone can for referance ....
83 Trekker SR5
NEW Trekker forum
Re: my 2WD build [Re: CJM] #1036650 11/13/11 11:23 PM
Rodgertheshrubber Offline
<img src="/forums/images/graemlins/cheers.gif" alt="" /> def going to be something i would like a ride in!
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
Re: my 2WD build [Re: Rodgertheshrubber] #1036651 11/15/11 03:07 AM
CJM Offline OP
as long as it's a "fair weather" day, your welcome to come along
83 Trekker SR5
NEW Trekker forum
Re: my 2WD build [Re: CJM] #1036652 11/20/11 03:10 AM
CJM Offline OP
got to work today making the rear cab mounts
as with the fronts .. plug welded
and yeah!!! , cab is no mounted to the frame
83 Trekker SR5
NEW Trekker forum
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6497 MB (Peak: 0.7746 MB) Data Comp: Off Server Time: 2026-06-07 07:27:24 UTC
