dumb question/idea 6g73 heads on 6g72 block? #1036976 10/27/11 10:14 PM
McAdam Offline OP
Here is the question first, then if you care, you can read my novel afterwards.......
Can I put SOHC 24v heads from a 6g73 in a stratus/sebring/avenger on a sohc 12v 6g72 montero block?
I realize I would need the associated intake/exhaust and what not, but is there any reason the heads and timing gear wouldn't bolt on? I figure the 2.5 would have a smaller combustion chamber, resulting in higher compression, and the smaller ports wouldn't be great for high HP, but would provide a nice low to mid range kick in the ass as far as torque goes with higher port velocity. and before you say anything, megasquirt to run it.
there are a few monteros around here in you pull it type junkyards, and a TON of chrysler products with 12v SOHC 6g72s and 24v sohc 6g73s. No 3.5 or 24v 3.0 engines though. I did find a page where a guy put a 12v 6g72 into a D50 truck. so, even the 3.0l fwd blocks will work in a rwd/4wd scenario. I could build the motor in the junkyard from the parts I want and walk out the door for around $200 with everything, including an ECU/wiring harness.
alright, a little background here.... i have a 1989 lwb montero 5 spd in great shape except for a motor that inexplicably has no spark on #2. mitsu dealer couldn't figure it out. swapped ECUs, distributors, sensors, coils wires, plugs EVERYTHING. it has a weak spark when its cold, and it goes away completely when its warm, only on #2. and it stumbles between 2k and 3krpm. the engine is old, has 254k on it, but has 180PSI on #2, and 100psi on #4 and 150 on #6. It's tired.
I bought a nissan FD35T for a repower project, but thats not going to happen for a year or 2.
If I had all the money I've ever spent on cars, I'd spend it all on cars.
Re: dumb question/idea 6g73 heads on 6g72 block? [Re: McAdam] #1036977 10/27/11 10:56 PM
Canyonero Offline
I'm just guessing, since I have a 6G74, but the 12v Montero block may be missing the relief cuts in the pistons for the 24v heads. My 6G74 24v DOHC has 4 small reliefs cut in the top of the pistons for valve clearance. Not sure if the 6G72 is the same, but it may be something to consider.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: dumb question/idea 6g73 heads on 6g72 block? [Re: Canyonero] #1036978 10/30/11 04:26 PM
McAdam Offline OP
I will look into that. I may have found a complete sohc 24v 6g72 out of a 2001 eclipse for $225 local, so I may just go that route.
That engine will for sure bolt up to my bell housing, right?
I know I will have to play games with manifolds, mounts and wiring/ecu. but at $225, already pulled, its way cheaper than I can find a RWD 6g72 for, and cheaper than my frankenstien engine just for the fact that I wouldn't have to re-gasket it.
Re: dumb question/idea 6g73 heads on 6g72 block? [Re: McAdam] #1036979 10/30/11 07:51 PM
sasnydley Offline
Might be easier to find heads off older 3.0 caravans. (6g72)_
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6039 MB (Peak: 0.6610 MB) Data Comp: Off Server Time: 2026-06-10 01:48:19 UTC
