Error code 1750 for the A/T. Help. #1037334 11/03/11 09:23 PM
Kirk Offline OP
On my '96 SR I have an error code of 1750. Which according to the transmission shop means the Solenoid block assembly needs to be replaced. However, also according to the shop I don't have one, I have individual solenoids.
Then they go on to say that since I have a '96 that was actually built in '95 that was the same time Mitsubishi transitioned from ODB-1 to ODB-2 so sometimes the codes don't match up properly.
They go on even further to say that they called their support people (whoever they are) who said I shouldn't even be able to get that code.
Anyone have an idea of what I need to fixe here?
KJ6GVJ
Re: Error code 1750 for the A/T. Help. [Re: Kirk] #1037335 11/03/11 10:07 PM
mike5 Offline
Did you get a check-engine light? How did you come across the issue? Is the tranny acting funny or not functioning properly?
Short of going to the dealer, you need to find a shop that has a Snap-On scanner with the module for Mitsubishi. Then have them scan and report their findings.
Re: Error code 1750 for the A/T. Help. [Re: mike5] #1037336 11/03/11 10:28 PM
Kirk Offline OP
Yes I have a check engine light but the trans works fine.
KJ6GVJ
Re: Error code 1750 for the A/T. Help. [Re: Kirk] #1037337 11/04/11 12:02 AM
How did they get that code? OBDII reader or a mitsu code reader(including the snap on tool)?
Good thing the tranny does work fine though.
Re: Error code 1750 for the A/T. Help. [Re: off-roader] #1037338 11/04/11 12:10 AM
Kirk Offline OP
I don't know what kind of a reader they had. Does it matter? would they get the wrong codes?
KJ6GVJ
Re: Error code 1750 for the A/T. Help. [Re: Kirk] #1037339 11/04/11 12:28 AM
OK, while I was away, I was doing some searching on Google for P1750 & Montero. I came up with this...
http://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/p1750-20745/
Where someone indicates it's a generic code for the Tranny and you need the transmission computer code reader to determine what's actually wrong with the transmission.
Then I found this... http://www.aboutautomobile.com/DTC/P1750/Mitsubishi which shows 3 TSB's related to it. Funny how we haven't really had too many on here experience the code. <img src="/forums/images/graemlins/confused.gif" alt="" />
HTH <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Error code 1750 for the A/T. Help. [Re: off-roader] #1037340 11/04/11 01:19 AM
mike5 Offline
I can tell you this: the code is not part of the OBDii specific codes. Rather it is manufacturer specific...in this case tranny related for Mitsubishi. But you should have a scanner that supports Mitsu from 96 run a scan to confirm. Then go from there.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6190 MB (Peak: 0.7102 MB) Data Comp: Off Server Time: 2026-07-14 23:09:39 UTC
