Re: Carbed to fuel injection setup -- Turbo swap [Re: JohnnyBfromPeoria] #1037395 11/07/11 04:14 AM
I just did a google and it looks like advance has them, autozone used to, and auto parts warehouse had the e8000 for around 80bucks.
Airtex/master is a big oem and aftermarket mfr.
Re: Carbed to fuel injection setup -- Turbo swap [Re: fasteddy] #1037396 11/07/11 01:10 PM
ForcedAir_Montero Offline
I've got the Master, never had any trouble with it. As for the fitting, I simply used a black iron pipe reducing bell coupling.
-Dave D
Reservoir of Useless Knowledge
"But... If I kill all the golfers, they'll lock me up, and throw away the key..."
-Bill Murray
'84&change Monty MPI Turbo, choptop, f&r lsd, swapped in AT- All the goodies!
Re: Carbed to fuel injection setup -- Turbo swap [Re: ForcedAir_Montero] #1037397 11/07/11 04:35 PM
dadrab Offline
I run run a Master E8000 on mine. It's not a bad pump, although I had to replace it last summer (in a damn school parking lot).
Interesting note: Auto Zone replaced the original for nothing seeing that it had a lifetime warranty. The replacement only has a one-year warranty.
with awesome audio.
Re: Carbed to fuel injection setup -- Turbo swap [Re: dadrab] #1037398 11/07/11 10:45 PM
Ed, it was built by you, as advised by me, and it's a wonder that it runs at all... <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: Carbed to fuel injection setup -- Turbo swap [Re: fasteddy] #1037399 11/08/11 04:51 AM
Kevin C Offline
Turbine pump ... To make it a good air pump it needs to have a lot bigger wheel and vanes. The problem is then its a really bad liquid pump since the load on the motor is very high when liquid hits the blades.
The roller / vane type pump is a positive displacement pump. While it wont move a lot of air, it will still pull a decent vacuum.
Re: Carbed to fuel injection setup -- Turbo swap [Re: fasteddy] #1037400 11/08/11 02:39 PM
dadrab Offline
Ain't that God's truth... <img src="/forums/images/graemlins/nana.gif" alt="" />
with awesome audio.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6166 MB (Peak: 0.7025 MB) Data Comp: Off Server Time: 2026-07-09 20:22:07 UTC
