Where can I run a wire through from engine compartment to interior GENII? #1037472 11/07/11 11:22 PM
mike5 Offline OP
I can't seem to figure out for the life of me how/where I can run wires from the engine compartment into the interior. I need to figure this out to run wiring for lights and other items. If there isn't a good spot from the factory, are you guys drilling holes somewhere? If so, again where?
If you have any pictures I'd greatly appreciate it!
96 Montero SR
Re: Where can I run a wire through from engine compartment to interior GENII? [Re: mike5] #1037473 11/08/11 03:07 AM
I drilled through, I think under the brake booster. I will take a look when the sun is back.
Re: Where can I run a wire through from engine compartment to interior GENII? [Re: mike5] #1037474 11/08/11 07:25 AM
Sure there's a OE hole in the firewall on the driver side. You'll have to push your wire through though which isn't easy but it's doable. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Where can I run a wire through from engine compartment to interior GENII? [Re: off-roader] #1037475 11/08/11 08:30 AM
There's a rubber grommet in the firewall where the harness goes through and there is one behind the kick panel too but you'll have to take off the inner fender to route the wires. All still pretty easy.
Re: Where can I run a wire through from engine compartment to interior GENII? [Re: OldColt] #1037476 11/08/11 06:30 PM
Grasscat Offline
I did as Charlie did, put in a rubber grommet ran the wires, plug it with body putty.
Michael j
TreadLightly! Trainer
Re: Where can I run a wire through from engine compartment to interior GENII? [Re: Grasscat] #1037477 11/08/11 08:01 PM
mike5 Offline OP
I might just have to drill. I looked by the passenger kick panel where the ECU is and there is a huge wiring harness that runs through there. But it is so tight that I'm afraid I'll ruin a wire. Plus, there just isn't enough slack to run multiple wires in the future.
I'll look forward to the picture.
Re: Where can I run a wire through from engine compartment to interior GENII? [Re: mike5] #1037478 11/08/11 11:37 PM
Looks like I did drill through and now that I look at it, I never sealed the hole once the wires were run trough.
The yellow cable is the bundle I have added, I am trying to recall where the dealer added fog lights passed through, I tend to think it might be where my wires are.
Re: Where can I run a wire through from engine compartment to interior GENII? [Re: OldColt] #1037479 11/08/11 11:42 PM
Isn't there a extra unused nipple on the main harness grommet like the gen1? I think I used one on my 95.
Re: Where can I run a wire through from engine compartment to interior GENII? [Re: fasteddy] #1037480 11/09/11 12:23 AM
mike5 Offline OP
Thanks Charlie. Can you get a picture from the firewall side as well? I'd like to see how far down it is? Also, was this drilled from the bottom of the car or from the top?
Thank you sir.
Re: Where can I run a wire through from engine compartment to interior GENII? [Re: mike5] #1037481 11/09/11 12:33 AM
I could not see a way to get a picture from the engine compartment, the hole is just under and to the inside of the brake booster.
If you fold the top of the carpet down just under the brake pedal you will see a punch out in the sound deadener, Once you look there and reference the picture I sent you should get a good feel of where I found to pass wires through.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6440 MB (Peak: 0.7673 MB) Data Comp: Off Server Time: 2026-06-10 01:49:14 UTC
