Re: Where can I run a wire through from engine compartment to interior GENII?
[Re: OldColt]
#1037482
11/09/11 01:02 AM
So you're saying that is a factory hole there basically? I will not need to drill to make it pass through?
[Re: mike5]
#1037483
11/09/11 01:43 AM
So you're saying that is a factory hole there basically? I will not need to drill to make it pass through? Just drill the hole. Stick a wire though it and see where it comes out.
Michael j
TreadLightly! Trainer
[Re: mike5]
#1037484
11/09/11 01:46 AM
The hole needs to be drilled, and is easy to get at that spot from the interior.
[Re: OldColt]
#1037485
11/09/11 08:07 PM
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6074 MB (Peak: 0.6792 MB) Data Comp: Off Server Time: 2026-06-22 11:18:13 UTCValid HTML 5 and Valid CSS
