pics of delo 400 in pajero Di-D after 9000km #1037829 11/11/11 04:27 PM
4ePikanini Offline OP
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: pics of delo 400 in pajero Di-D after 9000km [Re: 4ePikanini] #1037830 11/11/11 09:07 PM
That's pretty yucky <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: pics of delo 400 in pajero Di-D after 9000km [Re: 4ePikanini] #1037831 11/11/11 10:01 PM
P
pcc Offline
What's your point?
Re: pics of delo 400 in pajero Di-D after 9000km [Re: pcc] #1037832 11/11/11 10:34 PM
Just for interest sake. IMHO that's pretty clean for a diesel engine 9000km after it's last oil change. It's just goes to show that a good oil makes a difference.
Re: pics of delo 400 in pajero Di-D after 9000km [Re: 4ePikanini] #1037833 11/11/11 10:47 PM
Grasscat Offline
I agree, look very good to me.
Michael j
TreadLightly! Trainer
Re: pics of delo 400 in pajero Di-D after 9000km [Re: Grasscat] #1037834 11/11/11 11:26 PM
PHIL_ Offline
Agreed. Diesel oil turns from gold to black almost as soon as you pull out of the garage! I'm hoping you needed to do a valve cover gasket? Or maybe you're completing your oil change by getting every last drop, via sponges and paper towels? <img src="/forums/images/graemlins/lol.gif" alt="" />
Have you tried Rotella? Wonder how it stacks up against Delo?
Re: pics of delo 400 in pajero Di-D after 9000km [Re: Grasscat] #1037835 11/11/11 11:32 PM
hazy_daze Offline
I agree, it looks pretty good. Viscosity breakdown appears to have occured somewhat. And soot held in suspension seems to be at or near max capacity. How's come you went 4171.968km's overdue? What filter are you using? Do you have the same brands available down there that we have here?
Re: pics of delo 400 in pajero Di-D after 9000km [Re: 4ePikanini] #1037836 11/12/11 01:15 AM
P
pcc Offline
Used oil analysis would give some better information. I looked up Delo to see if they made an 0w-40 as Walmart is not stocking any more and parts stores want way too much. Can get 5w-40 Synthetic which may work as well. I don't know the price yet but will check it out.
Re: pics of delo 400 in pajero Di-D after 9000km [Re: 4ePikanini] #1037837 11/12/11 04:22 AM
Kevin C Offline
At the risk of sounding harsh.... It actually doesn't show anything. You dont have a baseline of what bad oil would look like and what the parts looked like immediately after you put the oil in.
Scientific Method
Also , without knowing the wear metal level in the oil, you dont know what was happening such as how did the additive package hold up.
Re: pics of delo 400 in pajero Di-D after 9000km [Re: 4ePikanini] #1037838 11/12/11 04:21 PM
Kevin C Offline
One last comment... One task of the oil in a Diesel is to hold soot in suspension. As far as I know, the generation of the soot is independent of the oil being used.
That said, the better an oil, the more soot it will hold in suspension, the blacker it should look. So if the oil is not black, either you did not generate a lot of soot or it came out of suspension (not a good thing) or you have a special filter.
That's where an oil test would help, since it takes out the subjective of how much soot is in the oil.
Also, oils have been undergoing reformulation to work with newer emissions systems. The anti wear additives have been changed in a number of major lubes. I would make sure your motor is compatible with the additive package in your oil.
web page
web page
Link to quote
What is Soot and what causes it?
Soot is a by-product of the combustion process in a diesel engine ù a carbon residue formed from fuel air and moisture in the combustion chamber after ignition. Soot particles are held in suspension by dispersant additives in the oil preventing the soot particles from agglomerating (sticking together) and attaching to the rings, pistons and liners. These suspended particles are what turn diesel engine oil black. When too much soot is generated and the additives can no longer keep it suspended, deposits will form on the rings weakening the seal between the pistons and cylinder liners. Upper end wear to rings, liners and pistons begins and if not corrected, will eventually cause severe lower end wear to the main and rod bearings, crankshaft, camshaft, cam bushing and turbo bearing.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6372 MB (Peak: 0.7470 MB) Data Comp: Off Server Time: 2026-05-29 23:58:06 UTC
