NGK Spark Plugs #1038064 11/16/11 11:18 PM
Clem1 Offline OP
Hi All,
Would it hurt anything to put NGK Iridium IX plugs in my 99 Montero (3.5 SOHC)?
I'm buying through Rockauto and the Laser Platinum & Laser Iridium plugs are $9.84 each and the Iridium IX plugs are only $6.38 each, so I was thinking I go with the "enthusiast" iridium plug and save about $20.
Good idea or is this a get what you pay for situation? <img src="/forums/images/graemlins/shame.gif" alt="" />
Thanks for your thoughts, <img src="/forums/images/graemlins/kewl.gif" alt="" />
Clem
1999 Mitsubishi Montero (Winter Package)
Re: NGK Spark Plugs [Re: Clem1] #1038065 11/16/11 11:59 PM
LRJ4x4 Offline
I would stick with the factory spec plugs.
Re: NGK Spark Plugs [Re: LRJ4x4] #1038066 11/17/11 01:41 AM
I used the NGK Iridium IX's and they seem to be a good plug. Factory spec on my '95 is "platinum-tipped plug," and I regard Iridium plugs as an upgrade. They weren't available when the truck was built. In theory the Iridium-tipped plugs should last longer than platinum ones.
Re: NGK Spark Plugs [Re: JohnnyBfromPeoria] #1038067 11/17/11 02:36 AM
Clem1 Offline OP
Thanks for your thoughts, gentlemen.
@LRJ4x4 - I agree with you that sticking with the factory spec plug is generally the way to go.
@JohnnyBfromPeoria - Thanks for sharing your experience with the IX plugs.
After further research on forum it seems the consensus is to go with iridium plugs for their longevity as it is a fair bit of work to get to the plugs.
Unless someone shares their poor experience with the IX iridium NGK spark plugs, I will go with JohnnyBfromPeoria's personal experience and put them in my Monty.
Thanks again,
Clem
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5998 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-07-15 03:23:20 UTC
