Filling Gas tank #1038078 11/17/11 06:59 AM
8
88thunderbird Offline OP
Since I got the sporty (01) when I pump gas it splash's back all over the body and tire. The only way to prevent this is to pump the gas real slow! like 4 times slower than normal .
Is there any way to correct this?
Re: Filling Gas tank [Re: 88thunderbird] #1038079 11/18/11 02:34 AM
DennisThompson Offline
You probably have a clogged or kinked vent line on your filler neck that won't let the air out of the tank that the gas is displacing. It could also be a kinked filler hose.
Just a thought, Dennis
Re: Filling Gas tank [Re: DennisThompson] #1038080 11/23/11 09:57 AM
Lou Offline
Dennis is correct. My son had the exact same problem with another car; the vent line was clogged....and it was a hell lot more a problem to access it than with the Sporty. Pull the tank off and blow the vent line , the one beside the filler pipe.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5937 MB (Peak: 0.6466 MB) Data Comp: Off Server Time: 2026-11-02 12:30:37 UTC
