3.2 Di-D Diagnostic DIY - without scan tool #1038155 11/18/11 01:54 PM
4ePikanini Offline OP
Locate the diagnostic port in the driver footwell underneath the fuel filler opener handle.
This picture is not from a pajero but the location is almost identical
Then ground terminal one with a piece of wire
Then switch ignition on and look at the dash lights.
Depending on what codes there are, the following lights may blink
- Check Engine Light - for engine codes
- Center diff lock light - for transfer codes
- Neutral green light - for auto gearbox codes
- ABS light - for ABS codes
To read these flashing lights are easy.
Count the long flashes followed by the short flashes.
Long flashes denominate 10's and short flashes denominate 1's.
Example
_____ _____ _____ __ __ __ __ (Error code 34)
Each code error will have a pause in between and then go to the next error code. At then end it will start from the beginning so if you think you missed a count. Just wait and count again to make sure you have all the errors.
Disconnecting the battery for 30 minutes clears most codes but some codes will only clear during driving if the problem has been solved and the ecu is happy with the diagnostic condition.
Fault codes below.
ENGINE CODES
AUTO BOX CODES
TRANSFER CASE CODES
here are the full manual downloads
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: 3.2 Di-D Diagnostic DIY - without scan tool [Re: 4ePikanini] #1038156 11/18/11 02:04 PM
manuals available here
http://www.pajeroclub.co.za/forum/viewtopic.php?f=52&t=3193
Please can a mod host here as not to hog the other forum's server?
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5900 MB (Peak: 0.6404 MB) Data Comp: Off Server Time: 2026-05-29 17:37:22 UTC
