anaerobic sealant #1038161 11/18/11 09:05 PM
Mad_Scientist Offline OP
I fitted a new rear main seal into the bracket/carrier (whatever) for my daughter's Montero and the service manual calls for anaerobic sealant, but I'm not sure where to put it. Any tips?
Also, is Vaseline OK on the end of the crank shaft to help bed in the new rear main seal?
Cheers fellas
Re: anaerobic sealant [Re: Mad_Scientist] #1038162 11/19/11 04:11 AM
sasnydley Offline
lock tight is a type of anaerobic sealant.
Re: anaerobic sealant [Re: sasnydley] #1038163 11/19/11 04:19 AM
KrzyDav Offline
they sell it at napa. I just used it on my rear cam caps. Made for metal to metal contact with tight , tight tolorance. The anerobic sealant as labeled is the just same thing as the gelled locknot.
dave h.
Re: anaerobic sealant [Re: KrzyDav] #1038164 11/19/11 01:09 PM
Thanks guys. I just noticed that Permatex anaerobic sealant is $50 for a tube the size of thread locker <img src="/forums/images/graemlins/zombie.gif" alt="" /> The seal carrier has a gasket between it and the block so I don't really understand why the anaerobic sealant is necessary.
Anyone change a rear main without it and had no issues?
Re: anaerobic sealant [Re: Mad_Scientist] #1038165 11/19/11 03:27 PM
MartySoCal Offline
Locktite 518 works well, costs $14 at Summit, your local parts store should have it, too:
http://www.summitracing.com/parts/LCT-37394/
Mopar sells the same stuff, works well.
Hope this helps!
Re: anaerobic sealant [Re: Mad_Scientist] #1038166 11/19/11 08:48 PM
KrzyDav Offline
a small tube of anerobic here is $8.00,,,,large 17. thety must have it priced wrong. My rear seal retainer just has a paper gasket on it. RTV is too thick in my opinion to use in that tight a space, esp. since you don't want to go back in and do all that work for any leak that developes. I'dcheck a different napa or try carquest.
dave h.
Re: anaerobic sealant [Re: KrzyDav] #1038167 11/27/11 10:22 PM
Thanks. I got a small tube of anaerobic sealant in carquest for $5. Should go in there more often really. It's a lot better than zombiezone.
Re: anaerobic sealant [Re: Mad_Scientist] #1038168 11/28/11 01:33 AM
mxmikie Offline
i use hylomar
Re: anaerobic sealant [Re: mxmikie] #1038169 11/29/11 04:50 AM
I used to use hylomar on copper head gaskets around the water and oil ports, and on intake gaskets. Good stuff. Hard to find sometimes. KopperKoat is a poor relation.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6323 MB (Peak: 0.7352 MB) Data Comp: Off Server Time: 2026-05-29 22:34:59 UTC
