Input Shaft Bearing replacement? #1038171 11/19/11 03:55 AM
Elbow_Greese Offline OP
Brothers truck is showing the typical signs of a failing input shaft bearing.
What does it take to replace one of those?
I know the trans needs to be dropped, but does it need to be dismanteled to get to it, or just the bell housing and the front of the trans?
Any and all help is appreciated as usual!
Thanks,
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: Input Shaft Bearing replacement? [Re: Elbow_Greese] #1038172 11/27/11 05:36 PM
OOP'S Offline
Here is a link for a lot of FSM's. It may help you out.
http://www.ncttora.com/fsm/
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Input Shaft Bearing replacement? [Re: OOP'S] #1038173 12/12/11 06:16 PM
E
Eck Offline
I just did a clutch change on my 3 VZE. Drop the gearbox, take off the pressure plate and clutch disk. You'll need a special tool to extract the bearing out of the crank. I used a 3/8" allen head bolt, app. 4" long and shaved one side of the head off so it would reach inside the inner race. Took a piece of flat stock, long enough to reach across the flywheel. Drilled a hole in the center so the bolt would go through and used a nut to slowly crank the bearing out. I pried a smaller screw driver between the inner race and the bolt so it wouldn't slip out. Worked great and I only needed one try to get it out. Be very careful when you insert the new pilot bearing as you can easily slip off the outer race surface and damage the seal.
Carefully look at the throwout bearing as the steel collar might be worn and needs replacement too. I installed a brand new Sachs clutch with flywheel etc. for 240.- Crank seal was extra though.
good luck,
ed
92 Xcab V6 4x4 SR5 5sp., Detroit locker rear, lim. slip front, Warn hubs, H4's, electr. fan, eng. oil cooler, 1 lift, open cat.
Re: Input Shaft Bearing replacement? [Re: Eck] #1038174 12/13/11 03:30 PM
G
Greg_Canada Offline
good luck,
ed
I think he means the input shaft on the tranny, not the pilot bearing.
A typical way to remove that bearing, is to pack it with greaase then get a rod the diameter of the hole in the bearing, and hammer it in there to make the grease push the bearing out.
89 4Runner
Re: Input Shaft Bearing replacement? [Re: Greg_Canada] #1038175 12/13/11 03:35 PM
Staceman Offline
Too messy.
Small peices of wet newspaper stuffed in there.
Easy cleanup..
Re: Input Shaft Bearing replacement? [Re: Staceman] #1038176 12/14/11 12:03 AM
Yup, talking about the input shaft bearing in the tranny.
I thought I replied earlier, but in any case, the decision was to go with a Marlin Crawler HD rebuilt instead of tearing into this one.
He's going to keep it for at least 5 more years for work field trips in New Mexico.
Thanks for the help!
Todd
94 2wd v6 extracab
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6122 MB (Peak: 0.6997 MB) Data Comp: Off Server Time: 2026-06-17 13:29:02 UTC
