rear coil spring wire diameter info #1038177 11/19/11 04:28 AM
KrzyDav Offline OP
SWB OEM coils 14mm , out of vehicle ht. 16 1/2 "
SR OEM " 16mm , " " " 15 1/2 "
Old Man Emu#910 17.3 mm " " " 15 1/2"
dave h.
Re: rear coil spring wire diameter info [Re: KrzyDav] #1038178 11/22/11 05:05 PM
W
WagonMaster Offline
Thanks Dave <img src="/forums/images/graemlins/cheers.gif" alt="" />
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: rear coil spring wire diameter info [Re: WagonMaster] #1038179 11/23/11 02:08 AM
KrzyDav Offline OP
after a couple weeks , I'm real happy with the SR springs. They are alot softer than the OME but way better than the OEM constant rate on this really windy "Hwy of Death" , HWY 41 I live on. They give me a little more clearance on my gas tank the builds up "a lift" of snow pack. Also better for towing lite loads. The OME would be good if I towed heavy loads all the time like Russell does. They were extreme overkill for my D.D. campmobile Raider.
dave h.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5975 MB (Peak: 0.6511 MB) Data Comp: Off Server Time: 2026-05-29 14:44:03 UTC
