Page 2 of 3 1 2 3
Re: mid-way through rear main seal... [Re: Sportege_Panicmech] #1038230 12/07/11 11:48 AM
TheGoat Offline OP
went to the racetrack last night, which is where the Kia is, and let it idle. no leak. only when i drove it up to the main gate and back it started leaking. i need to check for end-play of the crank..
So, i bought an 01 Kia Sportage. before i even drove it, i nick-named it The Goat.. it has been just like a goat.. stubbern at every corner...
Re: mid-way through rear main seal... [Re: TheGoat] #1038231 04/09/12 01:33 PM
TheGoat Offline OP
finally got around to replacing the rear main again. the one that was in there was just a regular autoparts store brand. i bought an OEM kia one. we'll see if this helps. took only about 8 hours total this time. went much smoother. didn't even use the shop manual. third time should be even easier.. i hope i don't have to do this a third time. <img src="/forums/images/graemlins/frown.gif" alt="" /> haven't started it yet.
Re: mid-way through rear main seal... [Re: TheGoat] #1038232 04/10/12 09:56 AM
blitz Offline
Re: mid-way through rear main seal... [Re: blitz] #1038233 04/10/12 10:22 AM
TheGoat Offline OP
hahahaa. thanks. i'm starting it up tonight.. <img src="/forums/images/graemlins/frown.gif" alt="" /> if this doesn't fix it, there HAS to be something wrong somewhere that is letting the crankcase build up too much pressure.
Re: mid-way through rear main seal... [Re: TheGoat] #1038234 04/10/12 12:08 PM
TheGoat Offline OP
actually, before i start it, i'm going to do a compression test. see if my rings are shot.. if they are... i don't know. rebuild or junkyard? i can do the rebuild myself..
Re: mid-way through rear main seal... [Re: TheGoat] #1038235 04/11/12 09:23 AM
blitz Offline
do your comp test with all 4 plugs out at the same time,then test one cyl at a time.
Re: mid-way through rear main seal... [Re: blitz] #1038236 04/11/12 11:12 AM
TheGoat Offline OP
yeah. that way the engine turns over more "free". i didn't bother doing the compression test before starting the truck last night. doesn't leak, yet.. we'll see. i've got to drive it around before it starts to leak. i pulled the dip-stick and there isn't anything blowing out practically at all, so it shouldn't be from excess blow-by. we'll see.
Re: mid-way through rear main seal... [Re: TheGoat] #1038237 04/12/12 05:57 AM
blitz Offline
good luck dude. i feel your pain. been down that road. pretty frustrating.if it does leak,throw some sawdust in there and sell/trade it. even for another sportage.
Re: mid-way through rear main seal... [Re: blitz] #1038238 04/12/12 10:32 AM
TheGoat Offline OP
i don't know... i think i'll do a junkyard engine in it if it does leak. i've still got some spare cash and haven't spent as much as a "good used" version yet.. i'm close. real close.. but haven't quite yet hit blue book.. engine would push me over, slightly, but i'm ok with that as long as it runs and doesn't leak!!! i'll have to post up my "build" once it's done, from start to finish. it's been work.. a LOT of work..
Re: mid-way through rear main seal... [Re: TheGoat] #1038239 04/15/12 12:16 PM
TheGoat Offline OP
drove it around some more... still no leak..
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6391 MB (Peak: 0.7624 MB) Data Comp: Off Server Time: 2026-10-22 02:16:05 UTC
