Water pump and timing belt #1038260 11/21/11 07:16 PM
bodyswapped8789 Offline OP
The time has come for a water pump and timing belt, would you all recommend spending the extra $$ on OEM or are there decent, reliable aftermarket parts that cost less and you would say are as good. Thanks
89 V6 manual trans Dodge Raider frame 87 cold weather pkg 2" body lift, Soft 8's wraped in BFG km2 33x10.5x15, JDM Pajero yellow Bosch fogs. Yackama basket. Duel bouncies gen II rear springs,gen II ft brakes,master and booster.
Re: Water pump and timing belt [Re: bodyswapped8789] #1038261 11/21/11 07:53 PM
IIRC, for the water pump GMB is a decent aftermarket brand. Otherwise I'd go OEM.
Also be sure you get one with the correct sized rear o-ring (you'll thank me later for that one). GMB ones seem to have the wrong size at least in my experience.
Also change your tensioner, pulleys, other belts & main crank bolt if you don't have the latest version... but you may already know that.
HTH
Re: Water pump and timing belt [Re: bodyswapped8789] #1038262 11/21/11 09:41 PM
P
pcc Offline
I couldn't justify the OEM pump so went with NAPA part, actually 1/2 water pump as I only had to buy the impeller side. No problems since 2006. I would also recommend the o-ring be OEM.
Re: Water pump and timing belt [Re: pcc] #1038263 11/22/11 03:04 AM
Another post with a Gates P/N apparently comes with the correct sized rear housing.
<img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Water pump and timing belt [Re: rxinhed] #1038264 11/22/11 09:57 PM
Does anyone know the diameter of the "Correct" o-ring, So I can measure it before getting into it?
Re: Water pump and timing belt [Re: bodyswapped8789] #1038265 11/23/11 01:57 AM
KrzyDav Offline
have you check Rockauto. You might find a good ,old on shelf, new pump , closout with dust on the box. (here I go again) Non Chinese metal. Last 2 pumps came with 2 o-rings one chys app, 1 Montero. Last one was rebuilt NAPA , the one before that was new NAPA High volumn,,,it had a thick cast impellor instead of stamped metal.
dave h.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6140 MB (Peak: 0.6839 MB) Data Comp: Off Server Time: 2026-06-07 09:11:28 UTC
