What is the best oil filter for Montero
#1038300
11/22/11 02:27 AM
Greetings!
I hope this finds everyone in good spirits. What is the best oil filter for 1994 Montero SR 3.5 liter? I've always used OEM, but considering K&N or Mobil 1.
I'm open for suggestions! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Happy Trails
1994 Montero SR 3.5 DOHC, Safari Snorkel, Diehard Platinum, OME suspension, factory rear locker, rear sway bar removed, Cobra 75 WX ST, 33" BFG KM2 New Mexico Land of Enchantment
Re: What is the best oil filter for Montero
[Re: matseel]
#1038301
11/22/11 03:07 AM
From what I've read...WIX or Amsoil filters are the best over the counter ones out there.I use WIX filters on my 3 rides & use fully synthetic oil. Change them every 5000 miles.
'02 Dodge Intrepid R/T 3.5L 120,000 '95 Silverado Z71 1500K 5.7L 225,000 '89 Raider 3.0 10,000 (since re-build..242,000 prior)
I'm sure others will chime in.
Va_Stumpy 89 Raider "Never judge horsepower by exhaust" 3.0 automatic stock as a rock Dual Bouncy Seats
[Re: Va_Stumpy]
#1038302
11/22/11 09:52 AM
Wix = NAPA Gold,,,, <img src="/forums/images/graemlins/kewl.gif" alt="" />
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: matseel]
#1038303
11/22/11 12:56 PM
[Re: pcc]
#1038304
11/22/11 04:01 PM
Bob Is The Oil GuyI use NAPA Gold. Just don't use Fram. John B.
[Re: JohnnyBfromPeoria]
#1038305
11/22/11 07:44 PM
I use WIX as well.
and x2 on not using Fram.
1995 Montero SR 2" Body Lift 35x12.50x15 Cooper Discoverer STT Aisins
[Re: matseel]
#1038306
11/22/11 09:50 PM
If you change your oil every 5000 miles, it probably doesn't make a big difference what kind of oil filter you use. I would guess that the less expensive ones like Wix or Napa would be just as good as the more expensive ones like K&N, at least over the course of 5000 miles. From what I remember, at least on my 1984 Honda Ascot motorcycle, a K&N oil filter costs 2-3 times what a "regular" oil filter costs, and isn't worth it if you chang the oil and filter every 5K.
 1989 Monty SWB, 2.6L w/MT, 15" alloys, 265/75 Dunlop Radial rovers, rear air shocks, Weber 32/36, SQ oil cooler, (SOLD Oct 2012) Southeast VA, USA
[Re: socal1200r]
#1038307
11/23/11 01:11 AM
I use Royal Purple synthetic & oil filter. 201K on the clock, so far so good
[Re: Angelo]
#1038308
11/23/11 01:24 AM
I use MOBIL 1 Extended Protection Full Synthetic, and a NAPA GOLD oil filter.
Keep On Rockin' In The Free World
88 Dodge Raider 2.6L 5spd, LSD, Bouncy seat
[Re: 89mitsuraider]
#1038309
11/24/11 01:46 AM
The Stock Denso oil filter (original to Mitsubishi's specs) would be my pick. You can even buy Mitsubishi oil, it's called eneos. However, I usually run Mobil 1 full syn. The stock filter costs no more than a wix/fram or any others.
Proud owner or driver of a 1989 Mitsubishi Mighty Max 4X4, 1989 Mitsubishi Montero SWB, 2008 Mitsubishi Endeavor, 2008 Mitsubishi Eclipse SE, 2007 Galant.
