Need a ball park value. #1038378 11/24/11 02:41 AM
Snowtoy Offline OP
Built this trailer for a friend who now doesn't need it. I am not sure what it is worth, but would like to recoup what I am into it for(about $800)
Specs.
5'x7' bed, 2'x2'x4' waterproof storage box, 7 tie down points oalong each the bed rail, 6 tie down points along each top rail, rear and center cross bar are removable, tarp sides set up for quick install/removal(about 2 minutes).
Re: Need a ball park value. [Re: Snowtoy] #1038379 11/24/11 02:48 AM
Jim_Paget Offline
I would think that you should be able get $1000.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Need a ball park value. [Re: Snowtoy] #1038380 11/24/11 03:11 AM
G
Greg_Canada Offline
Damn i like it alot! <img src="/forums/images/graemlins/cheers.gif" alt="" />
$1k for sure...
89 4Runner
Re: Need a ball park value. [Re: Greg_Canada] #1038381 11/25/11 04:08 AM
kewlynx Offline
x 3. Too bad you're too far away.
**ubi apis- ibi salus**
Re: Need a ball park value. [Re: kewlynx] #1038382 11/25/11 03:43 PM
Know the axle rating? Looks like an old boat trailer frame? Nice plan out. Wish you were closer x4.
Re: Need a ball park value. [Re: fasteddy] #1038383 11/27/11 06:14 AM
Snowtoy Offline OP
Thanks for the replies, I figured $1k was a fair price as well, just wasn't sure. I think I will ask $1150, so I can come down a couple hundred and still recover what I have put into it.
The bed, frame, axle and springs are from a longbed 2wd X-cab, so it should be fine for 1000-1500lbs with the stock springs.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6114 MB (Peak: 0.6807 MB) Data Comp: Off Server Time: 2026-07-09 16:14:15 UTC
