4cyl alternator compatible with v6? #1039343 12/22/11 07:08 PM
A
allochris Offline OP
Hi all, it's been about a month since I started hearing belt sqeeking noise at cold start-up, then last night it finally made lot of noise & stopped, at the same time I noticed my battery light came on (alternator went finally, just shy of 400000km!)
Yard in Smithers here has a 93 V6 for $50, is it compatible w/ 22re? (Both have the round plug connector)
Otherwise my other options are:
-Napa Reman. $162
-Bosch New 60amps $173
-Bosch New 70amps $238.92
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: 4cyl alternator compatible with v6? [Re: allochris] #1039344 12/23/11 01:21 AM
A
Well I took mine off & compared with the v6. they look identical! So I picked it up, installed it, & now it works! Happy holidays! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 4cyl alternator compatible with v6? [Re: allochris] #1039345 12/23/11 03:19 PM
G
Greg_Canada Offline
Get your original one rebuilt at an alternator rebuild shop... should cost about $90...
89 4Runner
Re: 4cyl alternator compatible with v6? [Re: Greg_Canada] #1039346 12/23/11 04:10 PM
Staceman Offline
Really?
Good to know. I wonder if the amperage output might be higher?
Re: 4cyl alternator compatible with v6? [Re: Staceman] #1039347 12/24/11 01:17 AM
OOP'S Offline
Really?
On my 90 V-6 it was 60 amps which is the same as the 22r I think.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 4cyl alternator compatible with v6? [Re: allochris] #1039348 12/24/11 03:20 AM
A
Well I took mine off ...
FYI, I avoided undoing the lower coolant hose to take the alternator out by snapping/breaking the lower (driverside) corner portion of the black plastic cover btwn the fan blade & radiator. It made the R&R so much easier & faster.
<img src="/forums/images/graemlins/oink.gif" alt="" />
& yes, it's 60amps.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6116 MB (Peak: 0.6818 MB) Data Comp: Off Server Time: 2026-06-21 12:24:13 UTC
