Update to slight miss, more questions! (Update 2!) #1039574 12/27/11 06:46 PM
dougl3nc Offline OP
Ok, more info to help diagnose this.
#2 Cylinder is dead at idle, but sparks starting about 1500rpm...even then though it's got a slight miss til redline.
Distributor?
ICM?
Anything?
1989 Raider SWB Auto 3.0L...It's ALIVE!
Currently on a shakedown cruise...
Re: Update to slight miss, more questions! [Re: dougl3nc] #1039575 12/27/11 06:48 PM
RECON45 Offline
Is there some crude on the inside of the dist cap? Thats the only thing I can think of if all the other cylinders are firing correctly.
Re: Update to slight miss, more questions! [Re: dougl3nc] #1039576 12/27/11 07:07 PM
Yup if everything else is firing right then my guess would be...
plug, wires, or dist cap.
Based on my 'limited' understanding an ICM issue would affect all cylinders not just one.
Re: Update to slight miss, more questions! [Re: off-roader] #1039577 12/28/11 04:02 AM
How about a bad ignition wire?
Re: Update to slight miss, more questions! [Re: rxinhed] #1039578 12/28/11 04:20 AM
joestruck Offline
Bosh "lifetime" wires fall apart like wet spaghetti.
Re: Update to slight miss, more questions! [Re: rxinhed] #1039579 12/28/11 04:57 AM
Va_Stumpy Offline
If you have enough slack...move the #2 wire somewhere else. If the miss follows;then you've found the problem.If not the trouble lies w/ #2....
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Update to slight miss, more questions! [Re: Va_Stumpy] #1039580 01/06/12 03:30 AM
dougl3nc Offline OP
Turns out that the optical eye in the 89 distributor controls the trigger of the fuel injectors as well as ignition...in a most precise manner at that!
Bought a remanufactured Distributor thru AutoZone, installed it, and now it runs PERFECT! $150 thru my commercial account, not bad when there aren't many options.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6181 MB (Peak: 0.6924 MB) Data Comp: Off Server Time: 2026-05-29 20:02:24 UTC
