Odometer and Speedometer went out #1039868 01/06/12 02:52 AM
5
504yota Offline OP
While driving the other day the speedometer started to jump then went out. I have a 92 4cyl with a five speed. Let me know what u think thanks.
Re: Odometer and Speedometer went out [Re: 504yota] #1039869 01/11/12 08:48 PM
fire4effect Offline
pretty sure the speedo cable broke.
Semper Fi,
Alfred
'91 4Runner V6 4WD 400+K
'10 Scion Xb
Re: Odometer and Speedometer went out [Re: fire4effect] #1039870 01/12/12 12:22 AM
Elbow_Greese Offline
Your year is close to the time they switched from cable driven speedo to the electrical version.
By the description, sounds like you have a cable driven one.
Easy to replace, just have to take the dash 1/2 apart to pull the instrument cluster (I think), then the rest is under the cab.
Good time to change out the radio if that was ever planned <img src="/forums/images/graemlins/lol.gif" alt="" />
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: Odometer and Speedometer went out [Re: 504yota] #1039871 01/12/12 05:06 AM
5
504yota Offline OP
Is there away to tell if it is cable or not? Would hate to take
My dash out if i don't have to
Re: Odometer and Speedometer went out [Re: 504yota] #1039872 01/12/12 05:23 AM
4Crawler Offline
Poke your head under the passenger side of the truck and look at the back of the transfer case. If you see a big fat cable screwed into the side of the case, you have a mechanical speedo/odo:
If there is a sensor screwed in there with a couple of wires coming from it, then it is electronic.
Re: Odometer and Speedometer went out [Re: 504yota] #1039873 01/14/12 02:24 AM
5
504yota Offline OP
Looks like I have the electric one on my truck.
Re: Odometer and Speedometer went out [Re: 504yota] #1039874 01/14/12 04:43 AM
4Crawler Offline
The FSM (Factory Service Manual) has a testing procedure for the VSS, using an ohm meter to check for the signals coming out of the sender. If that tests OK, then it could be wiring between the sender and the speedo/odo or the speedo/odo itself is the problem.
Re: Odometer and Speedometer went out [Re: 4Crawler] #1039875 01/15/12 10:22 PM
OOP'S Offline
Testing the VSS -- page BE-48
http://www.ncttora.com/fsm/1990-1995_4Rn...be/combinat.pdf
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Odometer and Speedometer went out [Re: OOP'S] #1039876 01/17/12 11:35 PM
5
504yota Offline OP
Tested the VSS didnt get any signal on the meter . I called toyota they want like $200 for a new one. Can the old one be repaired?
Re: Odometer and Speedometer went out [Re: 504yota] #1039877 01/18/12 04:05 PM
4Crawler Offline
Not sure on the repair, I think that is a passive device, might see if you can open it up and have a look.
Marlin carries some lower cost replacements:
- http://www.marlincrawler.com/transfer-case/parts-upgrade
Or you might see if you can snag one at a junk yard:
- http://www.car-part.com/
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6366 MB (Peak: 0.7404 MB) Data Comp: Off Server Time: 2026-10-24 23:55:30 UTC
