a question about replacing the coolant #1039878 01/06/12 05:53 AM
hadtomer Offline OP
Hey guys-time to replace the coolant (i mean the antifreeze of course). I have been using the same liquid for years (dealer approved) - but i have been wondering-
usually when i do it i unplug the small drain plug on the bootom of the radiator-open the cap-and let the coolant drain for a few hours-and then i re-fill the system,drain the air bubbles-and thats it. I have done this a few times in the past-no problems.
but what about the old coolant thats still inside the engine? in the internal heater core? i guess it doesnt drain out.
How do i make sure that ALL of the coolant has been drained from the system before i fill the new coolant? any ideas?
2001 sporty. 4 inch lift+ body lift-front lovlells coils+extended forks. reat tj. monroe shocks. full skid plate, auxilary fan. external oil cooler. maxxis 8060 235/75 R15 tires on american racing wheels. trackfinder rear diff lock.
http://www.cardomain.com/ride/3948684/2001-kia-sportage
Re: a question about replacing the coolant [Re: hadtomer] #1039879 01/06/12 01:30 PM
Happy Birthday 4runnernomore Offline
Hi had timer,
everse flush the engine through the coolinsystem until the only water comes out. ou will need to ensure your heater is on to ensure yo gt rid of all the antifreeze.
Cheers, Chris.
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: a question about replacing the coolant [Re: 4runnernomore] #1039880 01/06/12 01:41 PM
hadtomer Offline OP
hello mate.I dont need to flush the system- its not clogged or anything like that. it works fine. i simply want to make sure that ALL of the coolant will be out of the system.
Re: a question about replacing the coolant [Re: hadtomer] #1039881 01/08/12 10:46 PM
DennisThompson Offline
Flushing the system has nothing to do with removing a clog it flushes out the old coolant. It could help if you have a clog but if you want all new coolant flush out the old.
Dennis
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6010 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-07-17 02:20:08 UTC
