OD Solenoid #1040029 01/10/12 12:59 AM
dougl3nc Offline OP
89 SWB V6 Auto trans....where exactly is the OD Solenoid at? Found a piece on the side of the trans that takes one wire, but theres no part number on it.
1989 Raider SWB Auto 3.0L...It's ALIVE!
Currently on a shakedown cruise...
Re: OD Solenoid [Re: dougl3nc] #1040030 01/10/12 02:37 AM
Va_Stumpy Offline
That's it...One wire,held on w/ 2 bolts & sealed w/ 2 "O" rings.
I posted the part #'s in you OD post dated 12/23..
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: OD Solenoid [Re: Va_Stumpy] #1040031 01/10/12 04:38 AM
dougl3nc Offline OP
I thought there were two versions of the part? Still not sure which one I would need if that's the case.
I made a block off plate and tried it...still no OD.
Re: OD Solenoid [Re: dougl3nc] #1040032 01/10/12 04:56 AM
Va_Stumpy Offline
The first # is out of the mitsu/raider factory service manual.. The second was off the box of the replacement my mechanic got for me.It came thru toyota. Try the wire for a used one.
As far as the by-pass plate, take out the smaller "O" ring....the fluid needs to flow thru the 2 holes that are separated by the inside "O" ring.
Va_Stumpy
89 Raider
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: OD Solenoid [Re: dougl3nc] #1040033 01/10/12 02:17 PM
W
willwinchforfood Offline
OD on my truck stopped working. I was able to dig out the sealant on top of the solenoid and found that the ground wire was broken. Its a big fat wire that goes into the solenoid but the internal wires are something like 26 gauge. I had to resolder the wire to the body of the unit, if I remember correctly, and it worked fine. Use RTV to refill the area where you remove the sealant. Dig slowly and carefully as well. If you mess any connection up you can just resolder it when everything is apart.
John
SOLD!!: 91 LS 95 SR Rear LSD front 95 LS front brakes Dons Bumper 10k Gorilla/Promark winch Safari Snorkel Dual bouncy 31's
1991 Chevy Suburban 33's. All other stock.
Re: OD Solenoid [Re: willwinchforfood] #1040034 01/10/12 05:53 PM
mxmikie Offline
i have one
Re: OD Solenoid [Re: Va_Stumpy] #1040035 01/10/12 11:21 PM
dougl3nc Offline OP
Ok, did that but still no OD. Any suggestions?
Re: OD Solenoid [Re: dougl3nc] #1040036 01/10/12 11:40 PM
mxmikie Offline
did you check the temp sensor in the intake manifold ?????
Re: OD Solenoid [Re: dougl3nc] #1040037 01/10/12 11:52 PM
Va_Stumpy Offline
It's possible that the clearance after the plate is tightened isn't allowing sufficient fluid to pass between the ports.
Here are the options I see:
1 make a plate that has a "dome" in it to allow fluid to pass
2 repair your's per instructed by willwinchforfood
3 get the used 1 from mxmikie & drive on
I chased this problem for about 2 months.Replaced the solenoid & have been driving w/ no issues for 12,000 miles now.
Good luck!
Va_Stumpy
89 Raider
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: OD Solenoid [Re: mxmikie] #1040038 01/11/12 02:16 AM
mxmikie Offline
did you ????
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6356 MB (Peak: 0.7598 MB) Data Comp: Off Server Time: 2026-05-29 20:01:24 UTC
