Need some Willys Jeep P/U info #1040041 01/10/12 05:46 AM
rxinhed Offline OP
I have a friend that is looking to sell a nice '62 Willys pickup with a V8 conversion. I am trying to ID the engine. On the surface, the engine looks like a Chevy small block, but the distributor is on the front right. However, there is an apparent mounting area for a dizzy in the left rear, too?? The distributor is mounted in a Pete Jackson aluminum housing that also spaces the water pump away from the block.
[Linked Image] [Linked Image]
Help is requested, please.
Thanks, Russell
Re: Need some Willys Jeep P/U info [Re: rxinhed] #1040042 01/10/12 06:23 AM
4x4Wire Offline
Interesting. Are there any casting marks in the block? Specifically, belw the cylinder bank on either side?
Chevy V-8 conversions are the most popular due to availability of engine and similarity of mounting points.
Any indicator as to type of carb?
One picture hase some block casting numbers. Are those just the cylinder firing orde?
What type of tranny and t-case? If they have been changed, there may be a casting number in the bell housing.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Need some Willys Jeep P/U info [Re: 4x4Wire] #1040043 01/10/12 06:44 AM
rxinhed Offline OP
Trans/t-case are stock issue: 3 spd, Spicer 18, OD, PTO for winch.
I haven't moved the spiders out of the way looking for block numbers.
Re: Need some Willys Jeep P/U info [Re: rxinhed] #1040044 01/10/12 06:55 AM
4x4Wire Offline
Move the spiders and check for block casting numbers.
Also, Advance Adapters and Novack are the main providers for bell housing ant tranny adapters for engine conversions.
Looking for bell housing numbers may give you a clue. It would help to have housing depth measurement.
Also, were the engine mounts relocated??
John Stewart
Editor - 4x4Voice
Re: Need some Willys Jeep P/U info [Re: 4x4Wire] #1040045 01/20/12 02:44 PM
JAVYPRO Offline
No, no, no not a V8 <img src="/forums/images/graemlins/scared.gif" alt="" />
My dad has a 64 with the Hurricane flat inline 6. This truck is NICE, I would love to have one here in the states. How much is he asking for it, if you don't mind the question <img src="/forums/images/graemlins/smile.gif" alt="" /> Back home they are $$$$$$$$$$$$$ <img src="/forums/images/graemlins/shiner.gif" alt="" />
I am also curious on what they did to the difs.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Need some Willys Jeep P/U info [Re: JAVYPRO] #1040046 01/21/12 03:11 AM
rxinhed Offline OP
Aside from the engine, the truck is stock. His price is very negotiable. PM me for further details.
Re: Need some Willys Jeep P/U info [Re: rxinhed] #1040047 01/29/12 02:49 PM
superdawg Offline
Looks like a Buick 350, common in early 70s wagoneers and buicks of course.
They can have T90, T98, TH350 trans bolted to them. Correct bell housings will be needed. A chevy th350 wont bolt up.
SD
Re: Need some Willys Jeep P/U info [Re: superdawg] #1040048 01/29/12 11:10 PM
rxinhed Offline OP
Buick 350 is WAY different. This engine has positively been ID'd as a SBC with an aftermarket distributor and oil pump drive. The Buick dizzy sits at in the about the same area but is located by a integral cast timing/water pump cover.
Re: Need some Willys Jeep P/U info [Re: rxinhed] #1040049 02/10/12 04:10 AM
BigJim Offline
I don't know for sure what that engine is. I find it very hard to believe it's a Chevy.
The dist is general motors. The covers aren't like ANY I've ever seen on a Chevy.
Please somebody educate me on how a cam driven oil pump and dist can be moved from the rear to the front of an engine..
Yeah I know if one had access to an elaborate machine shop it could, perhaps, be done.. but really!
I'd guess an older Buick or possible even an olds or even a pontiac. It does still have a 12V generator. Which ages it considerably.
But Chevy? Really?
Big JIm <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Need some Willys Jeep P/U info [Re: BigJim] #1040050 02/10/12 04:05 PM
BigJim Offline
But Chevy? Really?
Well I have corrected myself! That thing is most likely around a 1963 289 Chevy engine that was built for marine or industrial use. So it was produced for boats and generators..
I'd like to have the thing just for grins and kicks. Can I get the guys number to call?
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6355 MB (Peak: 0.7458 MB) Data Comp: Off Server Time: 2026-10-21 18:57:16 UTC
