Welcome to 4x4wire's Mitsu tech forums. Arguably one of the best resources for technical info on Montero's as they relate to general use as well as off roading.
I recently got my ônewö æ95 Montero LS licensed and on the road. Recently, when accelerating to 60mph on the freeway, the engine has started to bump, lurch and hesitate. About every 2-3 seconds it will jar itself. Slowing down to around 55mph, the truck drives normally. The engine only acts like this at around 60+ mph. Any thoughts on what would cause the high-speed s-s-s-stutters?
Also, the center console clock no longer lights up and the compass/thermometer gauge blinks on start-up until I press the thermometer button. Then it works normally until the next time I start the engine.
I also noticed that the interior dome light does not work anymore, even when switched on manually.
The clock, compass/temp gauge and interior light worked normally until a week ago.
I would appreciate any troubleshooting insight, including performing an exorcism.
In terms of the engine stumbling, when was the last tune up?
In terms of the electrical issues have you checked your fuses? With so many things dying at the same time it's likely related to fuse or two going out.
If it's not the fuses then it is possible (albeit improbable) that each happened to go out at the same time.
There are light bulbs in the center console & it's possible that yours have simply burnt out.
As for the compass, when it's blinking does it tell you which way is north? If not, have you done the procedure to re-orient the compass? You need to press the reset button and drive in a circle until the compass orients itself. The procedure is in the owners manual.
Have you checked the bulb on the interior dome light? There may be built up oxidation where the bulb connects to the bulb socket. Try 'turning' the bulb in the socket to maybe scrape off & 'clear' the oxidation.
To perform an exorcism, please consult your local Roman Catholic Diocese. <img src="/forums/images/graemlins/lol.gif" alt="" />
