T100 auto gear selector adjustment #1040748 01/22/12 02:55 PM
jmoser Offline OP
My 96 T100 SR5 needs adjustment to the gear selector - I have to really work it to get it in Park. Its not just the light on the dashboard - it does not engage the parking pawl. Last week I found it rolling slowly as I was getting out.
Is this easy to adjust underneath at the trans or is it buried behind the steering column?
Jeff
96 T100 SR5 4WD Ext Cab, Warn Hubs, HD torsion bars, Bilsteins, Camper Shell, TJM bar, factory 31 x 10.5's, Powertrax No-slip rear, Recaro driver's bucket
Re: T100 auto gear selector adjustment [Re: jmoser] #1040749 01/22/12 09:02 PM
BamZipPow Offline
It's located in the engine bay by the firewall. It's pretty easy to git to and adjust. If yer in the rust belt, you might want to hit those threads with some rust penetrant... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: T100 auto gear selector adjustment [Re: jmoser] #1040750 01/23/12 04:12 AM
Jeff the marmot Offline
Just to mention one possible thing to check - I'm not familiar with the T100, but on some other Toyotas, if there's too much grease that's been pressurized into one or both of the driveshafts' grease zerks at the slip yoke, then it'll physically skew the transmission forward or back enough to cause the exact same symptom that you're describing. It's easy to check for that problem - just use a small screwdriver to press on the tip of the drive shaft grease zerks. Have a shop towel available. See if tons of grease wants to come out and the transmission position changes.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: T100 auto gear selector adjustment [Re: Jeff the marmot] #1040751 01/23/12 04:11 PM
jmoser Offline OP
Will the grease issue still happen with a 4x4 transfer case?
Jeff
Re: T100 auto gear selector adjustment [Re: jmoser] #1040752 01/24/12 07:18 AM
Yes, as long as you still have a slip yoke. Either front or rear driveshaft slip yokes (or both) could be overfilled with grease. It happened to me years ago from a Jiffy Lube or Grease Monkey, and I've heard the same symptoms and same cause from others on Toyota forums.
It isn't a "given", but it's a possibility.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6041 MB (Peak: 0.6693 MB) Data Comp: Off Server Time: 2026-07-14 00:25:18 UTC
