87 Montero - Oil Pressure Sender #1040789 01/22/12 08:39 PM
L
Lifecast Offline OP
Hey Guys
Hey guys I'm new, just bought a 87 Montero 4cyl for cheap 4x4in. As my 06 dodge ram 4x2 that gets stuck in any soft sand.
I can't figure out the oil pressure sender. My original one is intermittent and the guage sometimes works and sometimes doesn't. I tap on the sender and it works then later dies. I bought a new one from Autozone and the new unit only has one lead for a wire and the original had two leads. One for the guage and one for ground. When I connect the new unit it pegs full pressure with key on position then when the engine starts goes back to zero and stays there. Any ideas? Wrong unit? It's listed as the. Correct one with the montero and the raider in autozone and oriellys computers.
Re: 87 Montero - Oil Pressure Sender [Re: Lifecast] #1040790 01/22/12 10:55 PM
MarkG Offline
IIRC there are two different senders. One if the truck has a gauge cluster. The other if the truck only has a warning light. It sounds like you may have the warning light sender.
Re: 87 Montero - Oil Pressure Sender [Re: MarkG] #1040791 01/23/12 01:46 AM
Welcome to 4x4wire!
My 87 Raider has a gauge, pressure sender with one wire only, and what was a loose connector causing intermittent faults. I crimped the connector down with a pair of pliers and wall was good thereafter.
Russell
Re: 87 Montero - Oil Pressure Sender [Re: rxinhed] #1040792 01/23/12 01:53 AM
LandRaider Offline
For some reason all the parts stores will sell you a switch... For an oil pressure warning light. You need a gauge sender. They're about 30 bucks.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6035 MB (Peak: 0.6599 MB) Data Comp: Off Server Time: 2026-06-07 07:27:22 UTC
