Cam Caps Torque Specs #1040904 01/25/12 06:20 PM
Howah Offline OP
Can someone tell me torque specs for a 95 montero sr camshaft bearing caps (12mm and 10mm bolts). I am unable to locate them in fsm. Searched online and found specs for 6g72 to be 14 ft-lbs for the 12mms and 8 ft-lbs for the 10mms.
95 Montero SR
Re: Cam Caps Torque Specs [Re: Howah] #1040905 01/25/12 07:07 PM
Canyonero Offline
This is what I've been using for torque specs, since I couldn't find the information in the reassembly section of the FSM. This is on page 00-33 of the FSM.
The top part got cut off a little bit. The top section lists "Standard bolt and nut tightening torque" and the bottom section you can see is for "Flange bolt and nut tightening torque".
Edit: Just wanted to point out that they are listing the actual bolt size, not the socket size, so make sure not to over torque. Those bolts will stretch and break if over torqued.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Cam Caps Torque Specs [Re: Howah] #1040906 01/25/12 07:11 PM
heathdogg Offline
According to Mitchell OnDemand 6g72 and the 6g74 Camshaft bearing cap says 14-15 FT-Lbs
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Cam Caps Torque Specs [Re: heathdogg] #1040907 01/25/12 07:16 PM
According to Mitchell OnDemand 6g72 Camshaft bearing cap says 14-15 FT-Lbs
Wow, that's a huge discrepancy in figures. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Cam Caps Torque Specs [Re: off-roader] #1040908 01/25/12 07:23 PM
heathdogg Offline
I would assume it is that way due to the fact there are no bearings for the camshaft and the head and caps act as the bearings instead. I can always check my haynes but that won't be till late.
Re: Cam Caps Torque Specs [Re: heathdogg] #1040909 01/25/12 09:43 PM
Howah Offline OP
Is it the same for both the 12mm and 10mm bolts
95 Montero SR
Re: Cam Caps Torque Specs [Re: Howah] #1040910 01/25/12 11:31 PM
heathdogg Offline
Doesn't give any difference on the size of bolts for the specs.
Re: Cam Caps Torque Specs [Re: heathdogg] #1040911 01/26/12 08:01 AM
4ePikanini Offline
4d56
6g72
6g74
These are from autodata - take it with a pinch of salt - especially the crank bolt torques as they have been reviewed.
Use at own risk.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: Cam Caps Torque Specs [Re: 4ePikanini] #1040912 01/26/12 09:05 AM
Howah Offline OP
So it would be safe to say 14 ft-lbs for cam caps and 130 ft-lbs for crank pulley.
95 Montero SR
Re: Cam Caps Torque Specs [Re: Howah] #1079566 11/12/15 06:28 AM
mynion Offline
Old thread, but... the 10mm are 8Ft-lb's and after stripping 4 ask me how I know...
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6327 MB (Peak: 0.7410 MB) Data Comp: Off Server Time: 2026-06-23 11:15:41 UTC
