Re: Fuel Filter replaced now no acceleration power. [Re: conner] #1041063 02/01/12 12:54 AM
Huh?
He's saying to replace the fuel pump.
If the filter was clogged initially, the fuel pump works hard to get the fuel to the engine, having to "suck" harder on the line to get the fuel through. This may cause the pump to fail prematurely, but you don't know this until you replace the filter and it still doesn't work right. While you may have restored the proper flow to the pump, it has already become worn out and it doesn't supply enough fuel to the engine.
The fuel line goes from the tank, to the filter, then to the mechanical fuel pump, unlike a fuel injected engine, where the fuel goes through a strainer, then to the electric fuel pump, then to the filter, then on to the engine.
Re: Fuel Filter replaced now no acceleration power. [Re: JohnnyBfromPeoria] #1041064 02/01/12 01:01 AM
Kevin C Offline
Seems to me a partially failed pump would work better with less restriction.
Kevin
Re: Fuel Filter replaced now no acceleration power. [Re: scrubber3] #1041065 02/01/12 01:02 AM
conner Offline
PEACE OUT.
What about "I would explain the science behind it." I would like to learn something.
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: Fuel Filter replaced now no acceleration power. [Re: Lifecast] #1041066 02/01/12 02:03 AM
L
Lifecast Offline OP
I feel like an idiot.. I replaced the fuel filter AGAIN.. Saw the end of the hoses that connect to the filter a little worn so I cut about an inch off each side. Connected everything back together and it works fine. Either the Hose has a leak near the filter ends or the filter was clogged again.
Dennis
New to me , used 1987 SWB Montero 2.6l 4cyl auto. Stock so far.
Non Daily Driver, Not yet anyways.
Re: Fuel Filter replaced now no acceleration power. [Re: Lifecast] #1041067 02/01/12 02:22 AM
Kevin C Offline
I would guess you had an air leak at the rubber hose.
Glad to hear its working.
Kevin
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6153 MB (Peak: 0.6960 MB) Data Comp: Off Server Time: 2026-06-17 11:45:38 UTC
