Coolant CrossOver Tube #1041245 02/01/12 06:22 AM
Howah Offline OP
Where can I find the gasket that goes onto the coolant crossover tube located on the rear near the firewall on a 95 montero sr. Looks like one of this http://www.partsgeek.com/19mk9nf-mitsubi...z+W0133-1642697
95 Montero SR
Re: Coolant CrossOver Tube [Re: Howah] #1041246 02/01/12 06:51 AM
Canyonero Offline
If you are referring to the gaskets for the coolant tube at the back of each head the Mitsu part number is MD319539.
If you are looking for the O ring that connects between that pipe the Mitsu part number is MD030764.
I have pretty good luck with this place .
Enter the part number in the box to get the price. These are all OEM Mitsu parts.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Coolant CrossOver Tube [Re: Howah] #1041247 02/01/12 07:20 AM
You have read the FAQ post and seen where you can download the Mitsu ASA parts program right? <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Coolant CrossOver Tube [Re: off-roader] #1041248 02/01/12 07:03 PM
heathdogg Offline
That number crosses to a Fel-pro ES72872
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: Coolant CrossOver Tube [Re: Howah] #1041249 02/02/12 07:01 PM
Howah Offline OP
Thank u all. Apparently, I had the gasket laying around but not the easy installation type that sort of grips the tube so it doesn't fall off. Most likely the head is gonna come off again.
95 Montero SR
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6080 MB (Peak: 0.6733 MB) Data Comp: Off Server Time: 2026-06-09 22:00:29 UTC
