Page 1 of 3 1 2 3
CRAP! Major sunroof frame rot... #1041260 02/01/12 08:14 PM
seely Offline OP
So, I noticed I get a small trickle of water in the car wash from the passenger-side front corner of my sunroof. Didn't think it was a big deal, until I reached up to check the seal and CHUNKS of the sunroof frame flaked off just from me touching it.
I assume the drain plugs are clogged, and were letting water sit in the track. Is there anything anyone can recommend to save the frame and plug the leak? I honestly think I could pull the lower edge of the sunroof off with a screwdriver and minimal effort right now...
Third times a charm.
Re: CRAP! Major sunroof frame rot... [Re: seely] #1041261 02/01/12 11:52 PM
StockRaider Offline
pictures?
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: CRAP! Major sunroof frame rot... [Re: StockRaider] #1041262 02/02/12 12:11 AM
seely Offline OP
I'll see what I can do. It doesn't *look* bad at first so I'm guessing a camera wouldn't do it justice. However, if you touch it, you quickly realize that its just chunks of rust loosely hanging on to the corner.
Re: CRAP! Major sunroof frame rot... [Re: seely] #1041263 02/02/12 12:15 AM
IMHO (ZERO experience with this so take it with a HUGE grain of salt... perhaps the size of Gibraltar LOL)
Surface rust can be controlled/stopped.
Big chunks falling off = R&R part or all of that frame area.
<img src="/forums/images/graemlins/frown.gif" alt="" />
Re: CRAP! Major sunroof frame rot... [Re: off-roader] #1041264 02/02/12 12:23 AM
seely Offline OP
I'm almost wonder if I should just replace the glass/frame at this point. It almost doesn't seem salvageable -- I somewhat doubt I'd get a good seal without a ton of work and an ugly fix.
Side note: what's the easiest way to un-plug the drains?
Re: CRAP! Major sunroof frame rot... [Re: seely] #1041265 02/02/12 12:31 AM
METALMOVER Offline
Sounds like a problem, unless you want to spend a ton of money or time. I think Id look at trying to clean up the lip, fill the entire lip <img src="/forums/images/graemlins/patriot.gif" alt="" /> area with clear caulk with the sunroof open, put the caulk on the bottom edge of the sunroof, shut the sunroof, clean up the caulk, never open it again and call it a skyview roof.Prety redneck I know but better than duct-tape. <img src="/forums/images/graemlins/patriot.gif" alt="" />
1987 Raider,2.6,mt,78"Meyer snow plow,100lb. Doberman alarm,weber carb, lockouts from here- 1989 V-6,SWB, A.T. 4x4, 31'S
Re: CRAP! Major sunroof frame rot... [Re: seely] #1041266 02/02/12 12:43 AM
MarkG Offline
I used piece of copper wire. I don't recall the gauge. It was flexible enough to push it up from under the truck through the drain tubes. IIRC there are four. One tube for each corner of the sunroof.
Re: CRAP! Major sunroof frame rot... [Re: MarkG] #1041267 02/02/12 01:03 AM
seely Offline OP
Any way to do it from the top down?
Re: CRAP! Major sunroof frame rot... [Re: seely] #1041268 02/02/12 01:52 AM
You can but it's better to go from the bottom up since stuff is probably wedged in going down hence the reason it's backed up in the first place.
LP air may also work but perhaps others can chime in on how effective that may or may not be. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: CRAP! Major sunroof frame rot... [Re: off-roader] #1041269 02/02/12 02:05 AM
seely Offline OP
It's just that it's wet and nasty here, and I don't have a garage. Getting under the truck isn't very appealing to me right now. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6440 MB (Peak: 0.7650 MB) Data Comp: Off Server Time: 2026-06-23 01:20:16 UTC
