Transmission Throttle Cable #1041342 02/02/12 06:57 PM
Howah Offline OP
Anyone running their Monty with Transmission Throttle Cable disconnected? I've tried setting it as stated in fsm but doesn't have much power unless I disconnect it.
Am I hurting the transmission by disconnecting it?
Is my problem elsewhere?
When adjusting cable, what increments should I use?
95 Montero SR
Re: Transmission Throttle Cable [Re: Howah] #1041343 02/02/12 08:50 PM
LandRaider Offline
You've potentially got other problems then.
Absolutly Yes. This controls pressure on your clutch packs, and you will burn them out if you run it disconnected.
Yes
I'd do it exactly like the FSM says to. Check fluid levels exactly as the manual says to also.
It would help us if you filled out your signature, and told us what kind of vehicle we are diagnosing.
Please go here.
Forum Rules and have a read.
I hope you get it figured out soon.
Re: Transmission Throttle Cable [Re: LandRaider] #1041344 02/03/12 12:43 AM
Howah Offline OP
I should have known better.
My Transmission throttle cable is definitely broken at the crimp where line meets bracket on intake manifold. My tps is questionable. I was adjusting 2-3 turns back and forth each time on the cable last night for a good 20 miles drive.
95 Montero SR
Re: Transmission Throttle Cable [Re: Howah] #1041345 02/03/12 01:31 AM
TainterRacing Offline
The tranny needs the TPS as well.
1997 Montero LS with a motor swap a 1990 V6 12valve ported heads full 2.5in Ex I run stock tire size for Daily use, off road have 33x12.5 working on going trubo.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6014 MB (Peak: 0.6585 MB) Data Comp: Off Server Time: 2026-06-07 06:08:18 UTC
